MIDI #3 IN/OUT
Hi, I tried this link,
http://www.ucapps.de/mbhp/mbhp_core_lpc17_midi3_extension.pdf
But I couln’t open it
'cause a I need to connect more devices, I tought to use one more MIDI in/OUT ( #3 ) and two or three IIC modules
I have my third SEQ_V4 working but i need more Midi IN/OUTs
Sorry, I saw this:
This is the wrong schematic, it fixes a problem with a problematic MIDI device, but it isn’t standard!
Here the correct link:
http://www.ucapps.de/mbhp/mbhp_core_lpc17_midi3_midi4_extension.pdf
(I fixed the webpage and added the same link to the MBHP_CORE_LPC17 page now)
There seems to be a small copy/paste error in the PDF: both additional MIDI ports are numbered #3, whereas I think one of those should be #4? Which one?
Thank you! Fixed
Ok, I opened that file, only one doubt more: is it 5 Volts or 3.3 Volts in both MIDI OUT’S ( #3 and #4 ) because on the Core LPC17 Schematic on both MIDI OUT, #1 and #2, there are 3.3 Volts ( after the 220 ohms resistors )
I had used both #1 and #2 MIDI OUT ( 3.3 VOlts ) and they are working well
Thanks for your reply
Best Regards
Thanks again - the third error: wrong link, wrong enumeration, wrong supply voltage - ok, I created the schematic at new year’s eve and was in hurry… :wink:
The supply voltage is 3.3V since the output pins of the LPC17 UARTs don’t support open drain mode which would allow to pull the voltage to 5V.
Note: using 3.3V for the 1k pull-up at the output of the optocoupler shouldn’t cause an issue.
I changed it this way to avoid one additional cable to a +5V pin.
Hi Thorsten, I test the MIDI IN/OUT with 3.3 V and they work perfectly. No problem with 3.3 V on optocoupler. MIDI OUT #3 with 3.3V works well.
Thanks Thorsten for your support
Best Regards, Alberto
