MF module - sending control voltages for VCA
Hello and Merry Christmas.
I would like to use the MF module as a fader-automation in my mixing desk. The mixing desk itselfs has VCAs installed (volume control).
What about this idea:
Using the MF module to record and play fader moves (up..down) in a sequencer. Can I use any signal from the 74HC595 or the TC4427 of the motorfader module to control my vca’s ?
The desks VCA need the following voltages: 0db is no attenuation/fader@top, 6,34V = full attenuation/fader down
Or is it possible to grab the voltage at the fader (linear track)?
Or:
Using the mf module and the AoutNG module? Is it possible to send the midi data to the sequencer and to the AoutNG module at the same time/same midi channel?
(the AoutNG looks good because of the adjustable control voltages)
I would like to record the fader moves in the sequencer. The VCAs were controlled by the motorfaders. When playing the recorded data… the signal should go to the vca signal and the motorfader.
Thanks,
Roelli.
