I have problem with jittering pot values from motorfader core. I have switching power supply unit with 5A at +5V and 2A at +12V. I have 1000uF cap directly connected to the +5V input at MF core. When I testing this motorfader core alone, everything work OK. But when I conect another 3 cores in MB link to same +5V of my power supply jittering pot values starts.
I try conect next 1000uF caps to every +5V imput of my cores with bether result but still sometimes MF core send pot mesage without move fader.
sounds like a ground loop. “Starlike ground wiring” is very important here. Means: connect the ground/Vs pins of the core modules from a single point (e.g. from your PSU with separate wires), do the same for MF supply and fader ground pins. Don’t chain them from one to another core module!
I have made “Starlike ground wiring” for fader, but without success. Than I try cut connection between GND of MF pot and GND of MF chassis. And that’s problem. I have conductive front panel and GND of MF pot was join over the frontpanel.
