Dear Thorsten
I have looked at the problem for a good few hours now and apart from trying to devise a completely new parallel program to control the led’s and generate the SendDumps I can’t see how to interlace the read EEprom routines with the present design.
Perhaps you would look at a typical section of the code and see if you can make any suggestions.
}else{
//////// Pedal Radio Group Sysex ////// ////////////////////////////////////////
if( (pin >= 19 && pin <= 25) && (pin_value == 0)){
if(group1_selected == pin)// checks that current pin is the same pin as stored pin
group1_selected =26;//Pedal cancel pin = 26; pin not wired on DIN module
SendDump(dump_index = (26 - 19)); //Send Pedal Cancel Sysex to Sound Module
}else{
group1_selected = pin ;// current pin stored
SendDump(dump_index = (pin - 19));//Send appropriate Pedal Sysex message; dump_index set to 0
for(i=19; i<= 25; i++)//All LED's should be cleared for all group pins
MIOS_DOUT_PinSet0(i);
if(group1_selected !=26)// checks that the stored pin is not the cancel "pin"
MIOS_DOUT_PinSet1(group1_selected);// sets the Led
}else {
////////Tremelo Fast/ Slow Sysex///For comments see Comments in Pedal Section above/////
if( (pin >= 28 && pin <= 2
I am working on a function RecordMemory to read the groupxselected values into the EEProm at present. I have just about figured what to do.
It might be simpler to have a separate section to control the LED’s and generate the SendDumps rather than trying to integrate with the code above.
Regards Robin
