Just wondering if anyone has modified the firmware to integrate an external filter into the MBSID.
I’ve seen TK’s stuff with regards to the CEM filters, but I’m still not clear on how it works. I assume it requires an AOUT to get CV’s to the filter?
Yes, I just use a MBHP_AOUT module (MBHP_AOUT_LC works as well in the meantime) in order to control the analog filter. Beside of the CEM filter, I’ve a DIY moog style filter as well.
In MBSID V1, the CV output just follows the CutOff/Resonance, accordingly the internal filter of the SID should be switched off.
In MBSID V2, a free CV output mapping will be possible
AH, that sounds sweet then!
I still need to get my MBSID started. I was just planning ahead for my next SID project when I get a 6581.
