i was just suggesting linking the main parameter map on the main manual page.
I already added it, just press the refresh button of your browser
Maybe i confused you when i said I changed the name from “Parameter Chart” to “CC Parameter Chart”,
But this is no CC parameter chart, because the parameters are accessible via NRPN, and via various modulation sources.
Again - this was the initial question:
It seems that some people would prefer to automate MIDIbox SID V2 parameters with CCs instead of NRPNs due to DAW limitations.
Although CCs are limited in the number (only 128) and resolution (only 7bit), they could still cover your usecase…
…so, just list the parameters you would like to control and I will add a CC mode which will fit your needs.
Addendum:
currently following CCs are allocated
CC#00: select Bank
CC#01: Knob#1
CC#06: NRPN MSB Value
CC#16: Knob#2
CC#17: Knob#3
CC#18: Knob#4
CC#19: Knob#5
CC#38: NRPN LSB Value
CC#64: Sustain
CC#89: NRPN LSB
CC#99: NRPN MSB
I will add this to a new text file later, and release it in the SVN (no need to write a second documentation in the Wiki, which will be inconsistent whenever I’m doing changes)
So - which parameters would you like to control directly via 7bit CCs?
Going through the list of parameters at the moment for an unrelated project and i will make a list of what i think would be useful as soon as i have covered it all
I’d go for this idea, too. Having said that, if I can work out how to implement the current NRPNs on my XStation, I’d be happy for the moment (see my separate thread).
hi,i was busy last days..;i am very interested to control my sid by cc(only this on the P3)…by example resonance,cutoff,lfo rate..etc would you need a list?thanks guys for your works
