MBSID drum engine 30ms latency and MBSEQ
is it possible to use MBSEQ4 to implement this hot tip from MBSID manual (or something similar)?
“there is a simple trick which allows you to play a bassline and drum sequence in synch during a live session: just add an audio delay unit with t_delay=30 mS (e.g. VST based) to the SID outputs which are playing the basslines in order to compensate the timings.”
http://ucapps.de/midibox_sid_manual_d.html
No, this isn’t possible because the MBSEQ V4 based scheduler works MIDI tick based, not time based.
