I bought an old Gateway EV700 monitor at the thrift store for $4.35. Why? It has an encoder w/switch and a nice flat dial. For $4! Just needs a little cleaning and some black vinyl dye to look nice.
Wilba, i bought it like that Kinda lame, but wasn’t really planning on using the breadbox as a case anyways. BTW, i’m CADing out my front panel, and i was wondering if you knew anything off the top of your head that I should add because of V2. CC/Link button changed or something, right?
Yeah the answers are searchable elsewhere, but off the top of my head, Link becomes a “Shift” button, CC & Edit by default are PageUp/PageDown, using shift key to get CC & Edit functions.
If you’re building “step C” for V2, consider:
* a Volume “row” on the mod matrix under Filter.
* an extra LED for LFO Waveform, called “Positive” (you can have postive-only waveforms).
* MAYBE rename “Arpeggiator” to “Phase Offset” *** UNCONFIRMED!
TK did say that he won´t change his own front panel. But I´d translate this to “it will probably always be possible to access all functions of the MBSID through an ordinary step C CS”. When new functions are added, it´s not forbidden to think about useful additional ways to access functions. And of course more functions mean that some things have to be accessed through “hold shift, press button” actions as long as you don´t add new buttons.
MY build log is about 6 or 7 months old. Still stick at same point wiring display. Once I do that, I can finish wiring front panel and code my custom buttons… Bah.
Added bankstick. SOOO EASY. It’s just one chip, but it’s hanging right off main board. I urge everyone to get one.
Before you all go off and redesign your layouts, just keep in mind that just because TK has a nice panel that he’s not going to throw out, there’s no reason why people can’t design whatever layout they like. I just threw in some ideas, they’re not mandatory.
I haven’t posted on this in awhile because I was waiting for the dudes at monome.org to release their keypad kit. (yeah, its expensive for some buttons, but dangit i think it looks awesome)
i’m going to be using the 8x8 keypad layout for the modulation matrix, which means i’ll have that extra row for Volume.
must apologize for the image quality, i really need something else besides a phonecam…
Sizewise, its about the height of the C64 breadbox.
Ordering the rest of the DIN and DOUT boards from smash tonight…yay finally.
