hello y’all!
When I turn the Wavetablespeed all the way up (actually when it’s getting bigger than 127), the MBSID immediately is rebooting.
this bug is reproducabel on my system…
best,
julian
hello y’all!
best,
julian
Hi Julian,
can you please send me the patch which you are using to stimulate the bug?
I don’t need a special patch to cause this failure.
I can use any WT patch I want… for example the SEQ TranceBass from your preset library.
When no note is played, i can tweak up the rate without problems.
but when i play a note via midi and tweak the rate up while the note is playing it causes a mios reboot, as soon as the rate goes higher than 127.
best,
julian
This bug is fixed in v1.7a
