MBSEQV3 - ASM - changing patterns
hello everyone,
I know the asm version of seq will not further be developed or changed - thats allright - and so please see my question only as an hobby trial :slight_smile: and not as a request:
For me i want an additional adaption for mbseq3 in the MUTE SCREEN - Maybe someone has some skills and can give me a hint or bit help therefor. My skills in asm are very low, but i want to try that a bit.
The goal for me:
I want change patterns up and down of a selected bank by using rotary encoder in mute screen, because i am using very often the mute options of tracks and I want to change patterns (for the one of the 4 groups) there too.
The normal way is: I have to go from MUTE SCREEN to PATTERN SCREEN, and change the patterns there and switch back to MUTE SCREEN, which could be a bit time consumption for live performance…
So my try here ( CS_M_MUTE.INC ):
1. part: i have to exchange the MUTE Option for rotary encoder to SELECT Option of groups (That works very well):
CS_M_MUTE_GP_Callback
	;; do nothing if button has been depressed
	btfsc	MIOS_PARAMETER2, 0
	return
	;; part 1: use encoder for selecting groups (1..4: G1, 5..8: G2, 9..12: G3, 13..16: G4)
	;; if incrementer != 0, encoder has been moved
	SET_BSR	SEQ_BASE
	movf	CS_MENU_ENC_INCREMENTER, W
	bz	CS_M_MUTE_GP_Callback_Go
CS_M_MUTE_GP_Callback_Enc
	;; branch depending on button
	movf	MIOS_PARAMETER1, W
	andlw	0x0f
	JUMPTABLE_2BYTES_UNSECURE
	rgoto	CS_M_MUTE_GP_Callback_1
	rgoto	CS_M_MUTE_GP_Callback_2
	rgoto	CS_M_MUTE_GP_Callback_3
	rgoto	CS_M_MUTE_GP_Callback_4
	rgoto	CS_M_MUTE_GP_Callback_5
	rgoto	CS_M_MUTE_GP_Callback_6
	rgoto	CS_M_MUTE_GP_Callback_7
	rgoto	CS_M_MUTE_GP_Callback_8
	rgoto	CS_M_MUTE_GP_Callback_9
	rgoto	CS_M_MUTE_GP_Callback_10
	rgoto	CS_M_MUTE_GP_Callback_11
	rgoto	CS_M_MUTE_GP_Callback_12
	rgoto	CS_M_MUTE_GP_Callback_13
	rgoto	CS_M_MUTE_GP_Callback_14
	rgoto	CS_M_MUTE_GP_Callback_15
	rgoto	CS_M_MUTE_GP_Callback_16
	movlw	0
	rgoto	CS_M_MUTE_GP_Callback_Cont
	movlw	1
	movlw	2
	movlw	3
	movwf	MIOS_PARAMETER1
	;; do nothing when button has been released
	return
	;; get selected track(s) of current group
	SET_BSR	SEQ_BASE
	lfsr	FSR1, SEQ_SELECTED_TRKS_G0
	movf	SEQ_SELECTED_GROUP, W, BANKED
	movff	PLUSW1, TMP1
	;; clear all selections
	movlw	0xf0
	movwf	SEQ_SELECTED_TRKS_G0, BANKED
	movwf	SEQ_SELECTED_TRKS_G1, BANKED
	movwf	SEQ_SELECTED_TRKS_G2, BANKED
	movwf	SEQ_SELECTED_TRKS_G3, BANKED
	;; set new track group
	movff	MIOS_PARAMETER1, SEQ_SELECTED_GROUP
	;; store selected tracks in new groups
	movff	TMP1, PLUSW1
	;; request display re-initialisation
	bsf	CS_STAT, CS_STAT_DISPLAY_INIT_REQ
	clrf	CS_MENU_ENC_INCREMENTER	; don't increment pattern number
	;; part 2: get rotary direction (up or down?)
	;; part 3: Change pattern for that group
	return
Now the 2. part is to decide, whether the rotary encoder is rolled up or down, and at least the 3. part it have to change the pattern for that group.
Has someone an idea to solve the 2. and 3. part? thank you very much.
best regards,
rio
You could take the encoder handling code in cs_m_pattern.inc as a template
