MBLC pot Q
Hey…
In my LC i have 2 cores, the 2nd core just handles the master fader (regular pot) and a additonal 16x2 lcd…
Is it possible to makes use of another 2 ain inputs (so A1 and A2) on the 2nd core (for a joystick) and have it just send regular CC events over the midi chain?
Cheers.
Hi Dan,
sure, the USER_AIN_NotifyChange hook can be found in lc_mf.inc
Although “_mf.inc” implies that this file is intented for motorfaders only, this does not mean that you wouldn’t be able to react on any other analog control element from there.
yes, i imagined it would be possible and u make it sound so easy…but…where to start?  ???
Here is the tag:
LC_MF_FaderEvent
      ;; save the fader number in LC_FADER_NUMBER
      movwf      LC_FADER_NUMBER
#if TOUCH_SENSOR_MODE >= 2
      ;; in this mode, no value will be sent if touch sensor not active
      movf      LC_FADER_NUMBER, W
      call      MIOS_MF_SuspendGet
      bz      LC_MF_FaderEvent_End
#endif
      ;; store 10-bit LSB value in LC_FADER_POS_L
      movff      MIOS_PARAMETER2, LC_FADER_POS_L
      ;; store 10-bit MSB value in LC_FADER_POS_H
      movff      MIOS_PARAMETER3, LC_FADER_POS_H
      ;; shift the values to the right position like descriped in
      ;; the Logic Control MIDI implementation, chapter 12
      ;; 10 bit -> 14 bit (LC_FADER_POS_[LH] << 4)
      clrc
      rlf      LC_FADER_POS_L, F      ; 1
      rlf      LC_FADER_POS_H, F
      rlf      LC_FADER_POS_L, F      ; 2
      rlf      LC_FADER_POS_L, F      ; 3
      rlf      LC_FADER_POS_L, F      ; 4
      ;; MIDI MSB: (LC_FADER_POS_H << 1) | LC_FADER_POS_L[7]
      clrc
      rlf      LC_FADER_POS_H, W
      IFSET      LC_FADER_POS_L, 7, iorlw 0x01
      movwf      LC_FADER_POS_H
      ;; MIDI LSB: LC_FADER_POS_L & 0x7f
      movlw      0x7f
      andwf      LC_FADER_POS_L, F
      ;; for MIDIbox Link: notify begin of stream
      call      MIOS_MIDI_BeginStream
      ;; finally send value: E<fader> LSB MSB
      andlw      0x0f
#if MOTORFADER0_IS_MASTERFADER != 0
      skpnz
      iorlw      0x08
#endif
      iorlw      0xe0
      call      MIOS_MIDI_TxBufferPut
      movf      LC_FADER_POS_L, W
      movf      LC_FADER_POS_H, W
      ;; for MIDIbox Link: notify end of stream
      call      MIOS_MIDI_EndStream
      ;; thats all
      return
;;  This function is called by LC_MPROC_Received_Ex when a fader should
;;  be moved
;;  Input:
;;     o fader number in WREG and MIOS_PARAMETER1
;;     o LSB value in MIOS_PARAMETER2
;;     o MSB value in MIOS_PARAMETER3
LC_MF_FaderMove
      ;; save fader number in LC_FADER_NUMBER
      andlw      0x07
      ;; derive 10-bit value from received 14-bit value. Store result in LC_FADER_POS_[LH]
      movff      MIOS_PARAMETER2, LC_FADER_POS_L ; MIDI LSB -> LC_FADER_POS_L
      movff      MIOS_PARAMETER3, LC_FADER_POS_H ; MIDI MSB -> LC_FADER_POS_H
      ;; LSB = MSB[0] | MIDI LSB
      btfsc      LC_FADER_POS_H, 0
      bsf      LC_FADER_POS_L, 7
      ;; MSB = MIDI MSB >> 1
      clrc
      rrf      LC_FADER_POS_H, F
      ;; 10-bit value = 14-bit value >> 4
      clrc
      rrf      LC_FADER_POS_H, F      ; 1
      rrf      LC_FADER_POS_L, F
      clrc
      rrf      LC_FADER_POS_H, F      ; 2
      clrc
      rrf      LC_FADER_POS_H, F      ; 3
      clrc
      rrf      LC_FADER_POS_H, F      ; 4
      ;; finally move fader
      movff      LC_FADER_POS_L, MIOS_PARAMETER1
      movff      LC_FADER_POS_H, MIOS_PARAMETER2
      goto      MIOS_MF_FaderMove
from ain eg 2 I see:
      ;; a pot has been moved.
      ;; Send a MIDI event
      ;; save pot number in AIN_POT_NUMBER
      movff      MIOS_PARAMETER1, AIN_POT_NUMBER
      ;; save low-byte of conversion result in AIN_VALUE_L
      movff      MIOS_PARAMETER2, AIN_VALUE_L
      ;; save high-byte of conversion result in AIN_VALUE_H
      movff      MIOS_PARAMETER3, AIN_VALUE_H
      ;; prepare pointer 0 for last value entry
      lfsr      FSR0, AIN_VALUE_7BIT_BEGIN
      movf      AIN_POT_NUMBER, W
      addwf      FSR0L, F
      ;; now we can access the last pot value indirectly via INDF0
      ;; prepare pointer 1 for active value entry
      lfsr      FSR1, AIN_ACTIVE_VALUES_BEGIN
      addwf      FSR1L, F
      ;; now we can access the active value indirectly via INDF1
      ;; important for soft-overtake: save last pot value in AIN_LAST_VALUE
      ;; so that we can determine the direction (clockwise or counter-clockwise turn?)
      movff      INDF0, AIN_LAST_VALUE
      ;; the AIN driver delivers a 10-bit result
      ;; convert it to a 7-bit value and save new result in AIN_VALUE_7BIT
      ;; the calculation is simple: the 10-bit value has to be divided by 8
      ;; the common way for this simple division is to shift the value
      ;; three times to the right. Every right-shift divides the value by 2
      clrc                        ; value / 2
      rrf      MIOS_PARAMETER3, F
      rrf      MIOS_PARAMETER2, F
      clrc                        ; value / 2
      clrc                        ; value / 2
      rrf      MIOS_PARAMETER2, W      ; copy result to working register (WREG)
      ;; makes: value / (2*2*2) == value / 8
      ;; result is now in WREG, write result to AIN_VALUE_7BIT (INDF0)
      movwf      INDF0
      ;; if soft takeover has not been activated, continue behind the
      ;; handler
      IFCLR      INDF1, 7, rgoto AIN_Cont      ; (INDF1 == AIN_VALUE_7BIT[pot_number])
      ;; continue of active value == new value
      movf      INDF1, W
      andlw      0x7f            ; (mask out snap bit)
      xorwf      INDF0, W
      bz      AIN_Cont      ; values equal? continue!
      ;; else branch depending on clockwise or counter clockwise turn
      ;; means: last value <= new value
      movf      AIN_LAST_VALUE, W
      IFLEQ      INDF0, ACCESS, rgoto AIN_CounterClockwise
AIN_Clockwise
      ;; pot has been moved clockwise
      ;; exit if if new value <= active value
      movf      INDF1, W
      IFLEQ      INDF0, ACCESS, return
      ;; exit if active value >= last value
      IFGEQ      AIN_LAST_VALUE, ACCESS, return
      ;; else continue
      rgoto      AIN_Cont
      ;; pot has been counter clockwise
      ;; exit if if new value >= active value
      movf      INDF1, W
      IFGEQ      INDF0, ACCESS, return
      ;; exit if active value <= last value
      IFLEQ      AIN_LAST_VALUE, ACCESS, return
      ;; else continue
AIN_Cont
      ;; save 7-bit result in AIN_ACTIVE_VALUE
      movff      INDF0, INDF1
      ;; and clear snap bit
      bcf      INDF1, 7
      ;; !!!IMPORTANT!!!
      ;; MIOS functions normaly overwrite the FSR1 pointer, where currently
      ;; the active value has been saved
      ;; so don't use INDF1 anymore below (or calculate the correct pointer to the
      ;; pot entry once more)
      ;; !!!IMPORTANT!!!
      ;; now send a MIDI event which contains the new value
      ;; we read the entry from MIOS_MPROC_EVENT_TABLE
      ;; this has a big advantage: you can setup the "input" and "output"
      ;; events at one place!
      TABLE_ADDR MIOS_MPROC_EVENT_TABLE      ; this macro sets the base address
      movf      AIN_POT_NUMBER, W            ; add pot offset (number *2) to TABLPTR
      mullw      2                        ; multiplicate with 2, result in PROD[LH]
      movf      PRODL, W
      addwf      TBLPTRL, F                  ; low-byte
      movf      PRODH, W
      addwfc      TBLPTRH, F                  ; high-byte (+carry bit on overrun)
      ;; send first MIDI byte
      tblrd*+                        ; read first byte from table
      movf      TABLAT, W
      call      MIOS_MIDI_TxBufferPut      ; and send
      ;; send the second MIDI byte
      tblrd*+                        ; read second byte from table
      movf      TABLAT, W
      ;; send the third MIDI byte
      movf      INDF0, W            ; value from 0x00 to 0x7f
      ;; request a display update by setting DISPLAY_UPDATE_REQ,0
      ;; USER_DISPLAY_Tick polls this flag!
      bsf      DISPLAY_UPDATE_REQ, 0
      ;; thats all
      return
      END
So i have to take some of ain eg 2 and combine with the code in lc_mc.inc right…no other files need touching?
okay, I have no idea about this MIOS shiz…
whoever can get this workin gets a one of these joysticks for free…
// This function is called by MIOS when a pot has been moved
void AIN_NotifyChange(unsigned char pin, unsigned int pin_value)
   if( pin == 1 ) // J5.A1
      // send CC event for Joystick X axis
      MIOS_MIDI_TxBufferPut(0xb0);
      MIOS_MIDI_TxBufferPut(0x10);
      MIOS_MIDI_TxBufferPut(MIOS_AIN_Pin7bitGet(pin));
      return;
   if( pin == 2 ) // J5.A2
      // send CC event for Joystick Y axis
      MIOS_MIDI_TxBufferPut(0x11);
      return;
   // else continue with motorfader handling ...
does it look less complicated or not?
If yes: then it makes sense to wait for the MIOS C wrapper release… :wink:
yes, I can safely say I dont understand any of that - as for any C bidness, again the same ball ache…::slight_smile:
and btw, that snippet of code u posted has thrown me even more - it looks like javascript or summin now (does not tie in with the way the code is written in ur .inc etc…needless to say the build failed ;D
And I hoped that you are learning from all the tips and code snippets that I gave you in the past…
However, here the assembler variant… if it doesn’t work immediately, please first try to find out the problem by yourself to avoid a massive attack of ping-pong mails here in the forum (e.g. check the main.err file)
In distance to the C example this code sends the events via MIDI channel 16, because channel 1 should be reserved for the LC protocol
;;  This function is called by MIOS when a pot has been moved
;;  Input:
;;     o Pot number in WREG and MIOS_PARAMETER1
LC_MF_FaderEvent
        movlw   0x01
        IFNEQ   LC_FADER_NUMBER, ACCESS, rgoto LC_MF_FaderEvent_Not1
LC_MF_FaderEvent_1
        movlw   0xbf
        movlw   0x10
        call    MIOS_AIN_Pin7bitGet
        return
        movlw   0x02
        IFNEQ   LC_FADER_NUMBER, ACCESS, rgoto LC_MF_FaderEvent_Not2
LC_MF_FaderEvent_2
        movlw   0xbf
        movlw   0x11
        return
        ;; the rest of the LC MF handler
        ;; thats all
        return
T, I try to but I’m afraid when it comes to any code it’s a case of in 1 ear and out the other with me…always has been and MIOS/assembler is no exception…but hey, least u get one of these joysticks outta it  ;)
if it doesn’t work immediately…
It worked!
Cheers
