MBFM audio out
I’ve finished a MBFM.
All working great but when i assign OP12 and OP34 on audio1 there is no sound!
When i assign op12 and op34 on audio2 there is sound on audio1 and audio3!!!
op12 and op34 on audio3 is routing on audio2.
op12 and op34 on audio4 is routing on audio4.
Is it normal? any idea? i’ve missed something?
i think i have a bad yac or a chortcut somewhere!!
Could this be a problem with your audio jacks, e.g. left and right channel soldered to the wrong pins?
Hi TK
Thanks GURU!
My audio jack are ok (j4=audio1 J5=audio2 J6=audio3 J7=audio4)
I’ve got two YACs and i use the defaut .hex (V1)
You talk about stereo but i was planning to use in a mono way (separate outs ,2 independent synth jacks, one BDjack and one HH/snare jack)
on OP12 and op34 menu
if i assign only on 1 there’s no sound on the four audio outs!
if i assign only on 2 there’s sound on audio1 and audio3 , no sound to others
if i assign only on 3 there’s sound on audio2 , no sound to others
if i assign only on 4 there’s sound on audio4 , no sound to others
the audio 4 working great but others have no logical!
I’ve change the PIC (between 452 and 4685), test interconnection betwen core and opl modules,exchange all TL074 and look a the solder of YACs and OPL… I’ve fried my brain!!! :geek:
but MBFM sound greats! I’m very pleased with the quality of audio engine. all the rest working great!
i love it :heart:
May be I am wrong.
Could this be a problem with the some wire interconnections mistakes, shorts.
If you are looking from the OPL3 board side, connector J2 2 address control wires to the Core module RB4 - RB7 port .
from this diagram
http://ucapps.de/mbhp/mbhp_opl3_interconnections.pdf
Regards,
Janis
Hi Janis,
thanks
Yes i think to… but i check and recheck and recheck…reload solder on SMD… mmhh :frantics:
I conduct the investigation!!!
I see on the .ASM that for pic4685 with CAN bus other RB pins are adressed on core module…
there’s not many information about this subject!!!
For pic4685 do i need the change for interconnection modules?
Regards
Nicolas
Hi Nicolas,
if you’ve enabled the ENABLE_MBNET flag, this could be the reason.
In this case, RB3 is available at RE2, and RB2 at RE1 of the PIC18F4685
Could you please check your setup file? (resp. which one did you use for upload?)
Hi Thorsten,
I don’t enabled the mbnet!
I use the V1 and TK .hex!
Best Regards, Nicolas
So
after all checks…
never find the problem :frowning:
there’s three way happens to me:
1 SEPPUKU!
2 use like this : no separate outs , i can use only one jack!
3 change the YAC : find them on ebay ,desolder and solder
is someone have ever tested this config?:
instrument 1 to audio jack 1
instrument 2 to audio jack 2
instrument 3 to audio jack 3
instrument 4 to audio jack 4
is that it works?
Thanks
Best Regards
Hi tashikoma,
have you tried the FM-testtone application?
Hi Marxon
oops!
no sound with testtone…
interconnection test procedure results:
5V RS: RS DO D1 D2 D3 other pins 0V
5V A0: A0 DO D1 D2 D3 other pins 0V
5V A1: A1 DO D1 D2 D3 other pins 0V
5V WR: WR DO D1 D2 D3 other pins 0V
5V D0: DO D1 D2 D3 other pins 0V
5V D1: DO D1 D2 D3 other pins 0V
5V D2:  DO D1 D2 D3 other pins 0V
5V D3:  DO D1 D2 D3 other pins 0V
5V D4: D4 DO D1 D2 D3 other pins 0V
5V D5: D5 DO D1 D2 D3 other pins 0V
5V D6: D6 DO D1 D2 D3 other pins 0V
5V D7: D7 DO D1 D2 D3 other pins 0V
test have done with and without LCD: same result… D0 D1 D2 D3 always on 5V
Sorry i must have started from theses apps :rolleyes:
Please check again every connection between Core-Opl modules.
->PIC pins to the corresponding to YMF pins
Also cross check every pin next to each other to be sure there is now short circuit.
How do your power your FM synth?
I had similar problems because of a faulty PSU.
Best regards
Marxon
Thanks Marxon
I powering opl3 with an exotic design bipolar PSU!!!:
http://www.musicfromouterspace.com/index.php?CATPARTNO=WALLWARTKIT&PROJARG=WALLWARTSUPPLY%2FWALLWARTSUPPLY.php&MAINTAB=SYNTHDIY&SONGID=NONE&VPW=1356&VPH=508
I use this design in several projects and never had problems, I will test with a regular design one…
Best Regards
Without the bipolar power i’ve got the same interconnection bad voltages results… ( 4.80V with pic18f4685)
I’ve got 5cm cable between core and opl3
no shortcut at the ohm meter and integrity interconnection is OK
i take the cutter again and cut everywhere i could…opl and core
 try with different pic.
when i use a pic18f452 i’ve got an error at the end of the transfer reported when sending mbfm hex with mios studio (error #4)
but interconnection voltage are good… :nuke:
 gonna change the YMF262 (i have no spare and really don’t like desolder SMD)
i try with another  transformer for the 5V : the same
(i’m using 8V 500mA for mbfm full options without CV)
thinking i had bad YMF or something like that…
It wasn’t PSU problem…
it think it was a shortcut in the YACs … or bad YMF
I’ve rebuild a new OPL module and all is working perfectly!
YEAH!!!
THX for all
i will post pics soon
Finally! :slight_smile:
