Hey guys,
When playing a sound, it has a certain attack time. However, every sound has a different attack time, and sometimes you can even set it - with a knob etc.
If you play multiple sounds with the same gate, they will ‘top out’ at different times. If you play them in such a way that they ‘top out’ at the same exact moment, it’ll sound more ‘to the point’ and energetic. Otherwise you get a less exact feeling… which can sometimes be good, but not usually and not necessarily.
I’m looking over the draft spec for the 808 seq, and I can’t find an answer for this question anywhere… will the sequencer allow you to compensate for this? I assume that you can’t - so I’ll mention some points on why it’s a good thing to have…
I do understand that, from the systematic point of view, it should be the non-standard synthesizer (be it the 808 modules or something else) that should be compensating to adhere to a ‘standard’. However, this would mean several things… you’d either have to use a lot of audio delay lines (which again won’t be that wonderful for timing and will mess up the sound and cost a fortune), or you’d have to create a digital delay for the gates (which yet again would be worse for timing and would also cost more). And either of those will create a delay - which isn’t great for syncing up to other equipment running from the same main sequencer, and usually is difficult to compensate for - especially when you’re on a gig, every additional item is such a hassle! The MB Seq on the other hand could play the notes ‘before’ time, which would mean the notes would then be in perfect sync with the rest of the studio!
Thanks guys
