…mmm…is this just a guess?..or do you think its the only way to avoid the jitter?..i assume then its more a programming aspect rather than selecting components, right?
ok…why i ask is because i thought of building such a “sync-lock” on my own (i would buy this- but it´s soo expensive for “just” a midiclock…also like to have more midiouts, like they announced with the cinq-lock)…so when it depends on “just” programming, thought it may be possible with a pic (maybe even with mios ) to get a stable samplebased midiclock via a trigger input…
i searched this forum and also the www and stumbled across several projects (pic and arduino-based), but they all seam to be kinda “dead”, not further developed… :unsure:
the clockboxproject is great, but it also is heavily dependent of a stable midiclock from its source…would be great to have such a trigger-feature added to this…
did u read the article on the innerclock site posted above?..they describe the procedure there…
i put the mb808seq as master at 120bpm with a rimshot each quarternote…in soundforge i sampled 4 measures…so 16 rimshots in total…the distance between two rims should be exactly 22.050 samples @ 44.1Khz…the results are posted above…i know its not 22.0029 …should read 22.029 and so on, with a zero less (my fault, was a copy paste error :ahappy: ) <- corrected the readouts
