Figured it was long overdue that I shared some links to moosiks made with the MB808.
The Carrier Wave - Orion Busted (the carrier wave’s new belt remix)
Be sure to listen to his other tracks while you’re there. If you hear 808, it’s the MB808. Post-processing provided by Ableton and a big stack o’ Euro modules.
MB808 through a CGS Wasp filter + JH 4069 Distortion
This is a one-take demo (maybe skip the first 1:45 or so) I recorded to show off the same MB808 heard above. While repairing it I added in a CGS filter+distortion circuit to use up the additional pots left on the side of the PCB. This is a great example of using the A/B/C/D buttons to create a very diverse set of rhythms from a single 4-bar pattern! In real time!
edit: to be clear, the carrier wave is not me ![]()
