The Plan:
MB808
with Trigger-/ACCENT-out
without TR-808 analog section
The PCB should be single sidet, so I can etch it on my own ;D , and that should cost with chemicals max. 30€
But there are some unclear things now.
Questions:
- Do I need Menue Buttons under the LCDs?
- If I use the Midibox-Clockbox, for Start and Stop my Equipment, Do I need also on the MB808 this buttons (I actually left it out)
- If the MB808 is MIDICLOCK-SLAVE (clockbox is Master) The 3Digit 7segment LED-Display shows also the BPM?[/li
Is it or will it be possible to add a second 16x4 dualmatrix?
to have 8times a 16step sequence??? for me in most cases, 8 Instruments is all I use (for drums now) 8), it would be the ultimativ, super trupa phat mega groovy uuuuultra geile Drumsequencer (ok it is now already, but hey ;D ) -
On the 808 website: there are the Shematics and PCBs in eagle-format, but only in single files… so you have pictures like that, on your screen:
www.phatline.at/MB808/Accent.png
www.phatline.at/MB808/LED-Trigger.png
Should here everybody know what is going on here, should be it DO IT YOURSELF, or have some people paranoia? With this pictures I really cant understand the coherences. no, I know something of electronics… but a technician without a complete shematic, cant work ;) :-... so if somebody can send me the shematics, pm me…please- thankz!- The LED-Trigger is only for the LED??? or is it a ampliefier for the trigger signal? (again the complete shematic is left!
- If I want trigger out, that are able to trigger Roland Drummachine like the 808 909 or 606, Is this simple use a Doutregister? or Do I need a transistor circuit? to get more then 5V?, And whats about:…
- …whats now with the Accent Circuit?.. clear me up
- Where is the Accent POT that we have on the most Drummachines? For your info, the Accent Pots, modify the Accent Ammount..from 0 (no accent) to max on the accentet notes
- TK wrotes:
MBHP_AOUT_NG to output velocity:
Please note, that each track has only two velocity values defined (accented and not accented). It isn’t possible to set individual velocities for each step.
Sorry but why do that that way? ;D
If that work as you sayd, do I need expensive AOUT?, or I simple need, two outputs of a DOUT register, one with a resistor one without…and now you have already accentet or non accentet… why use a AOUT when it isnt “controllable” in fine steps like 0-127 ??? What I didnot understand here?
- The swing Pot: is a POT (a resistor…) and it is connectet to the Core where? J5 J6? which Pins? 0-5V?
- The following Pcbs, and its buttons…they are fully stuffed, or is there anything that, comes (maybe in future…)
Design for Fully stuffed with 2x 2x40 LCD: The complete pcbs (front and core…) consists of 3 Piece 200x150 PCBs.
The complete shematic is ready ;):
www.phatline.at/MB808/shematic.png
The FRONT-PCB—> I still have a some airwires… but ok, I dont care.. ![]()
www.phatline.at/MB808/frontpcb.png
The MAIN-PCB—> I still have a some airwires… but ok, I dont care.. ![]()
www.phatline.at/MB808/main808.png
_ If the fully stuffed is to big… _
3,6cm x 20cm is the size of the 4x16 Matrix with DTL switches
if you dont know about what I am talking bout…that are these http://www.phatline.at/MB808/pronbuttons.JPG (here 300 and 1 ;D )
Now what do the LCDs exactly? What shows it?..no away with them over the Matrix >:( ;D
and then I have still place for all the other buttons next to the Matrix, so it finally it fits in a smaller Rack with less “höheneinheiten” size…
and size/place nobody have ever to much…
ok here the finally front panel for the 2HE (HU) 19" MB808 that I will build
overview
http://www.phatline.at/MB808/808front-klein.png
left-detail
http://www.phatline.at/MB808/808-front-klein-links.png
right-detail
http://www.phatline.at/MB808/808-front-klein-rechts.png
how ever there exist a ready routet shematic and eagle pcb…
http://www.phatline.at/MB808/808-front-klein-pcb.png
The Main PCB:
http://www.phatline.at/MB808/808-pic-pcb.png
…not completely autoroutet…i cant wait…heh…and the trigger outs and Accent shematic are missing…because…I CANT FIND ANY DOCUMENTATION ABOUT THIS ( wahhh! wahhhhhh wahhhhhhhhhhhhhhhhh :![]()
All 4 PCBs can be placed on 2 single sidet PCBs from this, @ 6€ each…= 12€ euro for pcb
http://www.reichelt.de/?;ACTION=3;LA=2;GROUP=C911;GROUPID=3368;ARTICLE=33771;START=0;SORT=-artnr;OFFSET=1000;SID=31nnv@LKwQAR8AAGO9Hu47679e5705e3a39ea54a88904699bb8db
A Frontpanel in DXF format will come early.
A Case in DXF format will come also then
like I did bevor on a other project…:
open for Ideas—mike
