MB6582 Feedback Pots Question
Hey guys, is there any more info about hooking up the pots besides this:
Quote
How are the attentuating pots pictured on the rear of the chassis connected?
These are  not  volume controls. These are for using feedback to get the SID to have distortion, or with Filter Ext In turned on, extra resonance when using band-pass, or LP+BP or HP+BP. They are dual-gang pots, connected to J3_SIDx and J23_SIDx. Input goes to wiper pin (middle pin). Ground goes to left pin (facing towards pot shaft, pins pointing down). Output goes to right pin (facing towards pot shaft, pins pointing down).
I’ve been through all the pages several times, but haven’t found anything. I seem to remember reading they are 500K pots, but I don’t know where I read it. If they are dual gang, I assume there would be 4. Can I substitute 8 - one for each SID? I plan to add them on the top of my custom case, along the back edge.
Thanks,
Justin
