MB64seq LED question
Hya,
Now that i’ve read the recent developpements on the MB64Seq, one question came to my mind. When Thosten stated the Interface features to be static i got a little afraid my interface design won’t work the way i want it to work because i used 4 extra LEDs on the “Mute Track”- Buttons to indicate if a Track is on or off. Is it still possible to implement that function or do i have to wait for a PIC18f…- Firmware? Any help appreciated.
Thanks,
Simolch der Warst
I am really not sure about how the LEDs are set up compared to the new chip, but I believe it will be possible. It should be just a matter of latching the Digital output for every momentary push. I hardly believe that the MBHP is unable to do so, but if so it should be fairly easy to make a latch circuit to do what you want.
No Fears, DIY is always a possibility.
-Sephult :wink:
Hi Simolch,
you are right, it makes sense to add 4 LEDs for the track mute function.
The firmware already drives 32 LEDs (-> 4 shift registers), but only the first 16 are currently used. It wouldn’t be a problem for me to add even more functions to the spare DOUTs - any suggestions before I change the firmware?
P.S.: 32 LEDs are maximum, the PIC16F based sequencer will not support 64 LEDs due to memory limitations.
Maybe an LED-Display (german: LED-Segmentanzeige) for BPM, Patternnumber… would make sense?
I have no experience with SEQ ??? My MB64 will next days mutate to MB64SEQ ;D
By!
track ON/OFF(mute) indicators may be usefull
or current track indicators (4)
or current layer indicators (3)
or maybe a BPM indicator/flasher
or… :slight_smile:
good idea! :slight_smile:
Now that I’m thinking of the current track indicators LEDs…
Currently there are some digi INs with more or less the same function
DIN/J3/D4  (Start /stop)
DIN/J9/D5 (restart)
DIN/J9/D7 (stop)
http://www.ucapps.de/mbhp/mbhp_dinx4_mb64seq.pdf
perhaps one of those on J9 could be used together with these LEDs to form a ‘track select’ function of some kind.
If I’m not mistaken, currently a track is selected by tweaking a knob or digging into the menu.
Layer select buttons are already present.
But with a dedicated track select button, you could use the ‘soft takeover’ button to display the track contents without having to turn (& alter) a knob.
BTW I do like the start/stop combined in one button like the J3/D4.
-just an idea-
just thought about it again… maybe…
shift+trackmute= track select ?
Best wishes
DriftZ
Hi DriftZ,
the possibility to select the track directly is a very good idea! I would prefer a toggle function (1->2->3->4->1) which works faster in this case :slight_smile:
It should replace the stop function.
V101 can now be found in the MIDIbox64seq download section.
(I’ve implemented a shift button for the mute function like suggested by DriftZ, because the handling is more ergonomic :-))
New wiring diagrams:
http://www.ucapps.de/mbhp/mbhp_doutx4_mb64seq.pdf
Have fun! :slight_smile:
Coolcoolcool  :D
Can’t wait to try it out, darn I need to get this 2nd box finished asap… wanna see that BPM LED flashing ! ;D
best regards
DriftZ
Oh BTW, did you also do something with the ‘autosave’ thing ?
Hi DriftZ,
no — out of memory — it was already very hard to include these minor features into the firmware, I had to optimize old routines again and again to get just 4 or 5 free bytes for a new button function. Sometimes this makes fun, mostly not :wink:
Please check if the new release is already working without crashes.
Excellent stuff, havin mucho fun now - and the new info has helped in understanding ALOT!  ;D new led indicators also help…:wink:
Best…
Dan
Fine! :slight_smile: Any firmware crash so far? :wink:
Best Regards, Thorsten (has a bug-phobia).
nope, all peachy :wink:
Burned v101 to my 1st box, Seems to work just fine here, the “4step note-overview” is nice too.  Also noticed you have swapped the shift(shortcut) button, good thing I haven’t soldered my 2nd box’s buttons yet :slight_smile: ; direct track-select & shift-tracksel=mute is the other way round then I was thinking of tho :slight_smile: (I would have kept the direct mute & chosen for shift-select way, but its a matter of personal taste I suppose)
But again, great work TK !!
no — out of memory –
Not a big prob, the switch solution should work just fine  :)
