Hi there,
so this is it, my first post…
This forum and all the ucapps content have been of great value in understanding and building the mbbox sid project! Thanks to all for that first.
But at the time I’m stuck and haven’t found a solution to the problem, so I start this one.
I’ve build the basic Core-Sid setup for 8580 with pcb core v3 and pcb sid v2. I am using the latest v1.7 engine. with mios v1.9f. all tests passed and as I said I was able to install the sid app. I can change the patches (bankstick installed, lcd responds) via program change. Until here everthing’s fine and dandy.
Now here are the issues, which are really seperated from another, I guess.
1
I can play all patches and they sound ok, BUT all notes are hanging. That means they play in a legato style.
Checked the output of my sequencers and they either issue note-off or note-on with velocity 0. Seems to be ok.
As everything else with MIDI works, I’m a bit confused. Already checked another optocoupler, with same results.
All SID Interconnection Tests pass A OK.
2
The output volume is very very low. That means I have to crank it up like 70db to hear the sid. Naturally the SNR isn’t in the range of usability. But at least I get output
Tried s.th. with a function generator (actually an APC). When I inject the signal of the apc at the point where the sid chip output is it, too, is very very quiet. If I inject the Signal at a later point the signal is loud and clear…
Tried to bridge the output of the sid to tht later point, but to no avail (no sound).
I tested the the transistor and its readings are ok.
3
An maybe that has something to do with everything else…the PSU. I use the optimized C64 PSU circuit (v2).
I get correct voltage readings, when no IC is inserted and basically my setup works but:
When I power on the PSU nothing happens. I have to detach the SID module from the 14v line and then the core powers on and mios boots. Thereafter I can put in the SID modue supply. So far so good.
As I have many of the c64 psu’s I tried several of them and all gave the same result.
Can someone please help with this one? I’ve been unable to find a matching solution…
Greetings to all midiboxers,
sB
