MB SID freezes when "flooded" with midi
Ok, what I’ve seen so far: the note stack for osc1
is located at 0x15c-0x15f:
0150: 00 00 00 00 00 00 00 00  1E 00 00 00 1E 00 00 00
The first position of the stack contains “1E”, which means,
that note 1E = C-2 is played
Unfortunately the logfile doesn’t show a Note Off… ok,
so let’s assume that at this time the MIDI transfer
was already stucked. Let’s search for more informations…
The MIDI In Buffer is located at 0x500-0x53f
0500: 00 00 7E 40 00 0D 02 00  00 00 00 06 00 00 00 00
0510: 00 00 F7 2F 35 B0 2F 35  B0 2F 35 B0 2F 35 B0 2F
0520: 35 B0 2F 35 B0 2F 35 B0  2F 34 B0 2F 34 B0 2F 34
0530: 80 24 00 90 1E 7F B0 2F  34 B0 2F 34 B0 2F 34 F0
The last received events before the SysEx Request (which
begins at 0x53f) are: 80 24 00 90 1E 7F B0 2F 34 B0 2F 34 B0 2F 34
80 24 00: thats a note-off message for F#2
90 1E 7F: thats a note-on message for C-2
B0 2F 34: thats CC#47, Dec-Value 52
F0 …: SysEx message (RAM read) begins here
CC#47 (Resonance parameter) is a 4bit SID register,
it’s located at 0x117, bit 4-7:
0110: 00 08 00 00 F0 03 06 61  1F 0A 00 BC 9D 00 01 02
bit 4-7 of 0x117 is: 6
The 4-bit value of the received CC#52 is: 52 >> 3 = 6
In other words: the last MIDI events which were
received by the MBSID are stored correctly. There is
an active C-2 note, can you confirm this?
Ok, lets search for the logfile entry where F#2/C-2 was
sent, and thereafter 3 times a CC#47 with value 52:
Hm… and here I have a problem: the last combination
I found was:
    497465  2  –    128    42    0    1  F# 2 Note Off
    497466  2  –    144    36  127    1  C  2 Note On
    497468  2  –    176    47  110    1  —  Control Change
    497474  2  –    176    47  110    1  —  Control Cha
CC#47 is 110, and not 52
So, I’m missing something in the logfile. Maybe this was
also lost… (there is a character limit in the forum)
but now you should know, which informations are interesting
for me: the events at exactly the point where the note gets stucked
However, another point: During the analysis I remembered that
a friend has a similar problem with his M-Audio Delta1010
Soundcard/MIDI Interface. Once a lot of MIDI traffic is sent
out, the interface stucks and he had to reboot his PC.
I don’t want to say that you’ve exactly the same problem
(because of two things: you don’t need to reboot your PC,
and you are still able to send SysEx data)… but driver bugs
are things which have to be considered.
Therefore not only an updated logfile (which shows the
interesting moment) could be useful, but also the results
of a loopback test.
You can do this in the following way: after the SID stucked,
enable the MIDI merger via MIOS-Studio (select the
MIOS_MIDI_MergerSet command and send WREG=0x01". Thereafter
send some notes to the core module and check if they are
received back. Do the same test after power-on of the
module (doublechecking)
If you don’t receive any MIDI data back from the core
module when MIDI merger is enabled, you know that your
MIDI interface doesn’t send any CC/Note values anymore
Another point: it could be, that sending a SysEx message
“resets” your MIDI interface. In this case following
additional tests would be interesting:
  • enable MIDI merger via MIOS-Studio, thereafter try to
get the MBSID stucking again, thereafter check if
MBSID still returns the sent events (if not, you are
very sure that Notes/CCs are not sent by the MIDI
interface anymore)
  • once MBSID doesn’t react anymore, send a SysEx message
(e.g. MIDI Merger enable, or RAM read), and thereafter
send a Note-Off event of the note which got stuck. If
this works, then you know that a SysEx message resets
your MIDI interface… in this case I would say, that it
is definitely a bug in the driver of your interface
Any new inputs?
hmm thanks alot for the in-depth comment and analysis. i’ll try some more stuff tomorrow.
another thing that got lost 2 posts ago (got cut off) - is it possible that lack of midi-in gnd connection is the fault for all this?
is it possible that a hardware fault (a bad solder joint?) is causing such an error?
okay on to the point. there really isn’t a F#2off C-2on and three times CC#47 value 52 in the stream, i’ve checked both output dump of midiox and input dump and there simply isn’t such combo. i guess it’s safe to assume that the core got something else than i was trying to send it (correct me if i’m wrong)
though there’s a
    496335  2  –    128    36    0    1  C  2 Note Off
    496335  2  –    144    42  127    1  F# 2 Note On
    496341  2  –    176    47    52    1  —  Control Change
    496355  2  –    176    47    52    1  —  Control Change
but from the looks of “80 24 00” and “90 1E 7F” i assume the last byte of each is velocity (first one is off and the second one is on-127) so i guess there’s no mistake on your analysis :).
about the note C-2 being stuck - i’m really not sure… i remember it was something not too high and not too low so i guess it’s pretty possible it was C-2. but not for sure. i’ll record it all for the next test and i’ll choose the test notes and controller values more carefully.
also - i’ll try another midi interface i have (an M-AUDIO radium) and maybe i’ll find out that one’s okay… hmmm why the hell haven’t i thought about that before?! actually it’s quite possible that the ancient roland midi adapter i’m using mixes some stuff up!
i’ll check it out in the morning and report back. i hope it wasn’t such a stupid mistake  :-[  :-[  :-[
