On TKs MidiBox SID he/you use/s a 20x2 display with 5 buttons underneath it. When using a 40x2 I’d want 10 buttons under the display, I assume. Is that right? Oh, another thing - would I need another DIN board or anything special in that case?
Yes, you are right - 40 x 2 lcd accomodates 10 menu items on screen at a time, so 10 buttons under the lcd.
If you use one DINX4 board, you get 32 inputs, so if you are building a one SID machine with the minimal control unit (only added with the larger lcd),
you will be using up 13 of the 32 available inputs (10 menu item buttons, the back button and 2 inputs for the encoder).
You’re right. I just checked the pdf and it says there are 27 pins left. Just in case someone else is wondering and for some reason didn’t find it - like me
