Hey all,
I’m having a hell of a time locating the M3 20mm threaded studs used to attach wilba’s MB-SEQ PCB to the front panel. Anyone in the states have any suggestions?
Thanks.
Hey all,
Thanks.
Hey all,
Thanks.
Use long M3 screws and cut the head off.
Studs can be made out of 18mm lengths of M3 threaded shafts. Take a 20mm or longer M3 screw and cut it to 18mm of shaft using a Dremel and grinding disc. You can then round off the cut end by rolling it at a 45 degree angle on the Dremel grinding disc. Do not round off both ends! Later, you will put the screw’s original end (the end that wasn’t cut) into the threaded holes of the panel.
Thanks. My eyes seemed to not register the word screw… Cheers.
