MB Seq, iPad, Camera Connection Kit
Just thought I would post as I haven’t seen this mentioned yet. I picked up a CCK for the iPad and it works great with the MB Seq. You can plug the MB USB directly into the CCK and it will automatically find all 4 ports of the MB. Works fantastic for the virtual BLM Lemur app and any other app that uses Core Midi.
Luke
:smile:
Hello,
it is nice that it will work with your setup.
Have you tried a normal MIDI-USB adapter too?
All my tests failed with following device (Normaly it should work because midimate II can used by coremidi - it has no own driver):
iPad mini2 <-> Lightning to Camera Connection Kit <-> midimate II interface  (in a midi monitor app, that device name for IN and OUT is shown only a short time, then never again.. I am not able to use it)
iPad 4 <-> Lightning to Camera Connection Kit <-> midimate II interface (same here…)
If i use a usb-hub with external psu, it will not recognized the midimate too. So does anyone has an idea, what could be the reason?
M-Audio interface is also not working, ipad gave a message that it will not support it.
Thanks,
Greets,
Midi to USB adapters work for me with my iPad.  DIN MIDI inputs on my NI Komplete Audio 6 also work.  Maybe try the MIDIbridge app - it gives you a lot of control over iPad MIDI.
You may need to connect your usb-midi interface through a powered usb hub to the CCK, although mine works plugged directly into the CCK.  You definitely need to connect the midibox through a powered usb hub though, unless you’re powering the midibox with some power source other than USB.
