Hello Midiboxers!
I recently went through all (or most) :logik: midibox sequencer options and prepared a quick reference (crib) - list of functions and options. I don’t know if anyone else will find this useful, but I personally always prefer studying reference rather than userguide.
Now new quick reference version is vaialable on http://www.midibox.org/dokuwiki/ so it can be updated by others.
Also I marked some my comments with red. If anyone can explain them or provide solution - your input is welcome.)
Best regards
Gunars
MB SEQ functions - quick reference
Detailed info for options and functions of course is always available at
http://www.ucapps.de/midibox_seq_manual_m.html
Function Description Options
Dedicated button functions (can differ depending on hardware panel layout and MBSEQ_HW.V4 file)
1 Pattern 1,2,3,4
- Select pattern/track group (G1, G2, G3, G4)
2 Track 1,2,3,4
- Select track within track group (T1, T2, T3, T4) - 16 tracks total
3 Trigger layer A,B,C
- Select trigger layer A and B (holding C allows to select others)
- Gate | Acc | Roll | Glide | Skip | R.G - random gate | R.V - random value | No FX
- Still not clear to me how to access for editing the values for selected trigger layer, I can only access parameter layer values
4 Parameter layer A,B,C
- Select parameter layer A and B (C switches between C & D)
- Default: Note | Vel | Length | Roll (also CC, Pitch, Prob, Delay can be added via trigger selection menu)
5 Step View
- View and select steps if more than 16 are used
- 1…16 | 17…32 | …etc
6 Pattern
- Select pattern/track group G1, G2, G3, G4 from SD memory location
7 Song
- Select song parameters
- Song # | Position | Action (Stop, x1..x16, Jump Pos, Jump Song, Mixer, Tempo, Mutes) |||| Select patterns G1,G2,G3,G4
8 Edit
- Enter edit mode to edit parameter and trigger layer steps
9 Mute
- Quickly mute/unmute tracks 1…16
10 Solo
- Solo current track
11 <- | -> (Left | Right)
- Move cursor position
- Left doesn’t work in most cases
Left works when selecting trigger layers in other menus only right seems working
12 + | - (Inc | Dec)
- Same as jog dial encoder - increases/decreases the current value
13 Exit
- Quickly exit to top menu
14 Select
- (Press&Hold) Select steps to be controlled by All function
15 All
- Edit all selected steps according to Select function
16 Copy
- Copy steps from 1 (?) to selected #
- Is there a way to select from which step to copy?
17 Paste
- Paste copied steps
- Is there a way to select starting from which step to paste?
18 F1 (Clear)
- (Press&Hold) to clear selected track
- I think it would be more useful if Undo could be assigned to this in MBSEQ_HW.V4 file, but seems it is not possible
19 F2 (Select track)
- (Press&Hold) to select track from 1…16
20 F3 (Select parameter layer)
- (Press&Hold) to select parameter layer A,B,C,D etc
21 F4 (Select trigger layer)
- (Press&Hold) to select/assign (?) trigger layer 1…8
22 Rec
- Opens record menu
- Track # | Record (Live, Step) | Mode (Mono, Poly) | AStart (on, off) | Step # | TglGate |||| Port # | Chn #
23 <<
- Rewind (active only in song mode)
24 Stop
- Stops playback and resets position to beginning
25 Play
- Starts playback of patterns/song
26 Pause
- Halts playback
27 >>
- Forward (active only in song mode)
28 Metronome
- Toggles metronome on/off
29 Fast
- Activates Fast mode for quicker value selection with encoders
- Speed options for Fast can be changed in MBSEQ_HW.V4 file
30 Scrub
- (Press&Hold) + jog wheel allows dynamic changing of actual position
Menu functions
31 Menu+Scrub
- Toggles loop mode on/off
32 Menu+GP1 (Mixer)
- Opens mixer view for 16 tracks (12 pages can be switched with +/-)
- Midi port | Midi channel | Prog change | Volume | Panorama | Reverb | Chorus | CC1 | CC2 | CC3 | CC4
- Changing midi channel didn’t work (tried just once hovever);
Not clear how to change/select new map;
pages 8 to 12 holds CC1=128,CC2=128,CC3=16,CC4=50 not clear how this works and how to change assignment to other CC numbers it looks like only theese CC messages can be remaped?
33 Menu+GP2 (Event)
[*] Opens track setup editor
[*] Track # | Type (Note, Chord, CC, Drum) | Step # | ParL # | TrgL # | Port # | Chn # | Edit Name
34 Menu+GP3 (Mode)
[*] Opens track mode editor
[*] Track # | Track on/off | Normal, Transpose, Arpeggiator |||| Hold (on, off) | Sort (on, off) | Restart (on, off) | Scale (on, off) | Sustain (on, off)
35 Menu+GP4 (Direction)
[*] Opens track playback direction editor
[*] Track # | Select playback mode (Forward | Backward | PingPong | Pendulum | Rand.Dir | Rand.Step | Rand.D+S) |||| Fwd # | Back # | Replay # | Repeat # | Skip # | Itv # | SyncM (yes, no)
36 Menu+GP5 (Divider)
[*] Opens track clock divider setup editor
[*] Track # | Clock # | Divider (normal, triplet) | Sync to Measure (on, off) |||| Timebase selector (1,2,4,8 …etc)
37 Menu+GP6 (Length)
[*] Opens track length editor
[*] Track # | Length # | Loop # |||| Quick length selection (4,8,16 etc)
38 Menu+GP7 (Transpose)
[*] Opens track transpose editor
[*] Track # | Transpose selector (-7 oct … +7 oct) | (-7 sem … +7 sem)
39 Menu+GP8 (Groove)
[*] Opens track groove editor
[*] Track # | Groove style (off, shuffle … etc) | Intensity # |||| Step # | Dly # | Len # | Vel # | Num Steps #
40 Menu+GP9 (Trigger)
[*] Opens track trigger layer selection menu
[*] Track # | Gate | Acc | Roll | Glide | Skip | R.G | R.V | No FX
41 Menu+GP10 (FX)
[*] Opens FX editor
[*] Local (Echo, Hum, Limit, LFO) |||| Global (Loop, Scale)
[*] Echo (Track # | Repeats # | Delay # | Vel.Lev # |||| FB Velocity % | Note # | Gatelen % | Tcks %)
[*] Hum (Track # | Intensity # | Note [on, off] | Vel/CC [on, off] | Length [on, off])
[*] Limit (Track # | Lower # | Upper #)
[*] LFO (Track # | Wave [off, sine … etc] | Amp # | Phs % | Steps # | Rst # | OneShot [on, off] ||||
[*] Note ([on, off] | Vel [on, off] | Len [on, off] | CC [on, off] | ExtraCC# | Offs # | PPQN #)
[*] Loop (Mode [all tracks / step view …etc] | Offset # | Steps # | Loop [on, off])
[*] Scale (Control [global, G1, G2 …etc] | Root [Keyb, C …etc] | Selected scale [major, minor …etc]
42 Menu+GP11 (ManualTrigger)
[*] Manualy triggers steps, (Press&Hold)+Select for sync to measure
[*] Not clear how to operate this function, what selected tracks in uper row of LCD mean and how to change them
43 Menu+GP12 (Morph)
[*] Opens track morphing setup
[*] Track # | Mode (on, off) | Dst.Range # | Value # |||| Morphing control (also by CC1)
44 Menu+GP13 (BPM)
[*] Opens BPM settings editor
[*] Mode (Auto, Slave, Master) | Preset # | Tempo # | Ramp #s | Fire Preset | Preset Page |||| MClk (USB1 etc) | In (?) | Out (?) | Din PPQN # | Ext.Restart | Tap Tempo
[*] Wasn’t able to change valuses for In and Out, maybe some other settings have to be changed
45 Menu+GP14 (Save)
[*] Opens save menu
[*] Group # | Location # | Target # | Save |||| Category | Label
46 Menu+GP15 (Midi)
[*] Opens midi setup editor
[*] Transpose and arp (Port # | Chn # | T/A Split [on, off] | Midd.Note # | Reset Stcks)
[*] Section Control (Port # | Chn # | G1 # | G2 # | G3 # | G4 # | Fwd [port] | Reset Stcks)
[*] Midi Router (Node # | In [port)] | Chn # | Out [port] | Chn # | Default Port)
[*] Misc (BLM_Scalar port [on, off] | Midi Monitor)
47 Menu+GP16 (Sysex)
[*] Sysex directory not found on card
[*] Not all required folders are created with disk format - midi folder was also missing
Utility functions
48 Utility+GP1 (Track select)
[*] Select active track
49 Utility+GP2 (Copy)
[*] Copy steps from 1 to selected #
50 Utility+GP3 (Paste)
[*] Paste copied steps
51 Utility+GP4 (Clear)
[*] Clear selected track (No options - Wipes the track instantly!!!)
52 Utility+GP5 (Move)
[*] Moves some steps (copy and paste together)
[*] Is there a way to select step range
53 Utility+GP6 (Scroll)
[*] Scrolls the steps across
54 Utility+GP7 (Random)
[*] Generates random events
[*] Track # | Generate | Clr | Util | Undo |||| LayerA # | LayerB # | LayerC # | TrgA # | Trg B # | Trg C #
55 Utility+GP8 (Undo)
[*] Undoes last operation
56 Utility+GP9 (Save)
[*] Opens save menu
[*] Not sure about location - is it like copying from one momory location to other?
57 Utility+GP10 (Record)
[*] Opens record menu
[*] Track # | Record (Live, Step) | Mode (Mono, Poly) | AStart (on, off) | Step # | TglGate |||| Port # | Chn #
58 Utility+GP11 (Mixer)
[*] Opens mixer view for 16 tracks (12 pages can be switched with +/-)
[*] Midi port | Midi channel | Prog change | Volume | Panorama | Reverb | Chorus | CC1 | CC2 | CC3 | CC4
59 Utility+GP12 (Options)
[*] Opens options menu
[*] Measure # | Pattern # | SyncChange (on, off) | Paste/Clr steps |||| Remote (auto, client, server) | ID # | Port # | Request connection (no)
60 Utility+GP13 (Port Mute)
[*] Allows muting of output ports
[*] Def | USB1 | USB2 … AOUT | Bus1 | Bus2
61 Utility+GP14 (Disk)
[*] Opens disk menu
[*] MSD USB (disabled, enabled[Pres&Hold]) | Midi files (import, export, play)
62 Utility+GP15 (Mute)
[*] Quick mute of all tracks/channels
63 Utility+GP16 (UnMute)
[*] Quick unmute of all tracks/channels
