Hello,
I am unable to use my Roland MC -909 with the Midibox seq I just built. Here is a summary of the testing I have done:
Connect lpc-17 midi out 1 to MC-909 midi in. Set the appropriate ports and channels on the MB-SEQ to route a track to the midi output. - MC-909 does not respond to notes, CC#, clock, NOTHING! I have also tried live play and triggering from an external controller, and I can see the notes coming in and out with the MBSEQ midi monitor, but nothing happens on the MC-909.
Connect ext. midi keyboard directly to 909 to make sure it’s working - everything behaves as expected. Notes trigger, CC#s register, etc. - this tells me that settings on the keyboard, and the 909 are correct. - now I think the problems is with the output of the MB-SEQ
Connect the MB-SEQ to my computer via midi interface. When I look at the incoming messages in midi-ox, notes and CC#s are transmitted as expected. Ext. keyboard is able to pass through the MBSEQ and play VST’s and etc…
This leaves me stumped. I thought maybe it was an issue with using USB to power the MBSEQ, so I hooked up a 7.5v 1-amp power supply and although my LCD backlights are a little brighter, The MBSEQ still won’t trigger the MC-909
Can anyone suggest another test or idea? The midi settings in MC-909 are very limited and simple. I don’t think it’s an issue on the 909 anyways since it works fine when I take the MBSEQ out of the equation.
Thanks for your help!
