Hi, wanted to build a simple Serial to midi interface. I would love to use a GM5, but this is for a old PC running Win98SE ( a modded I-Opener) with a dedicated purpose of running old tracker softs. There is no way to upgrade to a true SB gameport; no ISA or PCI connectors. The mobo does have USB but Win98 doesn’t support Class Compliant USBMidi. I’ve tried a ‘no name’ USB midi, NO GO, (even tried to force it to use Yahama driver but got BSOD). And polytech GM5 driver won’t install (had to try!) Perhaps there is a work around with the GM5? But a sane person would just use XP or >
So a M-Audio midisport 1x1 with their Win98 USB driver may work, but a serial or parallel port midi interface (Midiman PC/S ) is sure to work, these may be a better choice due to 98’s USB support, timing-wise.
So this bring me to my questions about MB Router as a Serial to Midi interface. If I set the default interface to ‘COM’ and edit the code to only one IIC Midi interface, how much more should I comment out? No need for DIN or DOUT, nor filtering, do I need to comment out these unused sections, even thou they won’t be called?
I know that this is a REALLY old code base and much better options out there, but it’s a retro thing ![]()
