MB-LC Button assignment
I still a bit confused on the button assignments for the MB-LC. Since it’s a logic controller, most of these buttons should auto assign.
http://www.ucapps.de/midibox_lc/midibox_lc_buttons.pdf specifies what the buttons should do, but what if I want them to do other things?
Same with the faders and encoders? Will I just have to manually assign everything in Ableton?
Just looking for a little clarification on the matter, thanks!
…you can do it the way you want. Assign it in Ableton so it matches the standard LC assignment of the MIDIBox application (the way I would do it) or reconfigure your box to match the preset assignment of Ableton (probably the harder way).
Remember: The MidiBoxLC is dumb. The host application interpretes the function of a received MIDI command.
Greets, Roger
