I have a MB-808 style sequencer which seems to be working apart from one problem.
When I select ALL with the instrument select encoder it crashes the machine and does a force reboot.
Any ideas?
Cheers
Al
Any ideas?
Cheers
Al
which MIOS and midibox_808 firmware version are you using?
the mios is 1.9g and the firmware is the setup_808_with_swingpot.hex version.
cheers
I uploaded this firmware variant (of the midibox_808_v1a package), but can’t reproduce the crash.
It’s possible to select all instruments with the encoder, and changes take place on all tracks (as expected)
Does it crash immediately at your side, or are you doing something special?
the encoder selects the other instruments and they behave as expected.
Someone else suggested that it could be a power issue, which makes sense as when I select ALL all of the leds light up very briefly then it crashes.
Cheers
Al
yes, this makes sense - it could be related to a power issue!
You can check this by disconnecting the LCD backlight.
yes it was the power. I changed the power source and all’s good.
I’ve only hooked up the leds for the 16 steps. I am going to add the other 17 buttons, for pattern/song select etc.
But I’m thinking of leaving out the 17 leds that go with these buttons. Do you think it would be a problem for navigating your way around? Or do you think there are any leds out of these 17 that would be essential?
Cheers
Al
I would say:
1st priority: GP and ABCD LEDs
2nd priority: Mute/Pattern/Song/Edit, Gate/Aux and Live LED
3rd priority: Stop/Play LED
4th priority: Rew/Fwd, Shift and Alt LED
yeah, i called it: http://eight-oh-eight.org/phpbb2/viewtopic.php?t=583
