MB-6582 + SID6581-chip
Hi all,
I already started soldering my mb6582 now. I want to stuff my unit with 4 x 6582, 2 x 8580 and 2 x 6581.
I know about the different psu-options,the jumpers to get 9 or 12v and about different filter-caps for the different SID-versions.
My question is : Are there any changes in the main.asm-file required when I want to stuff some 6581-SIDs?
Or just put in,select the filter caps and psu-option and be happy?
THX
Brother303
I believe the only difference now between the 6581 and 8580/6582 builds of MB-SID firmware is the default filter cutoff range.
See the manual:
http://www.ucapps.de/midibox_sid_manual_e.html
I recommend you use the same firmware (setup_mb6582.asm/setup_mb6582.hex) for all PICs which will have the default set to the 8580/6582 range, and then for the slave that has 6581, change the range for just that SID, in all ensembles.
If you could be bothered, you could hard-code the default range so all ensembles would initialize with the 6581 range for one SID pair, but then you’d have to manage this difference every time TK does a new release.
Hi Wilba,
thanks,this helps much. It`s ok to me to make a little change in the filter-menu (ensembles).
Dont think Im going to code…
Thanks lot,Wilba! Great support!!
;D
