The MB-6582 PCBs will be available for purchase from SmashTV’s store some time in the near future.
SmashTV has voluntarily taken on the massive effort of assembling kits of parts for the MB-6582 base PCB, and now willing to stock the PCBs in large quantities, so you should all count yourselves blessed that he slaves away to make your life easier (and your MIDIbox build cost as low as possible).
SmashTV does not have the PCB artwork from me yet, because I am a paranoid perfectionist and before asking someone else to put up their own money to stock hundreds of PCBs I designed, I want to be absolutely sure there are no problems with the PCBs whatsoever. SmashTV might order 100 or 1000, either way, I owe it to him and everyone building a MIDIbox from these boards to get it right.
Therefore, before PCBs get made, I want to finish building an MB-6582 from the last PCB run, to validate the changes I made from the prototype AND to see if any other improvements can be made. While I have built up the base PCB and fixed the base PCB errors already, the delays in getting panels meant I did not start control surface construction until yesterday.
Doing things right takes time, and I don’t have much spare time.
So, if you are on my notification list already, you will be emailed when SmashTV has PCBs to buy.
If you are not on my notification list, you can email me at Jason.S.Williams @ gmail.com to be put on the notification list.
While you patiently wait for the PCBs, read the entire MB-6582 wiki, which should explain everything you need to buy and how to build it:
http://www.midibox.org/dokuwiki/wilba_mb_6582
Do not send emails or PMs to SmashTV or me with the following content:
- When PCBs will be available?
- What other parts do I need?
- Can you send me a kit of everything I need?
- There is a lot of information to read in the wiki, can you read it for me?
I do not want to deter the MIDIbox newbies from building this project, but there is the expectation that you read the MB-6582 wiki completely _ in addition to _ the MB-SID V2 documentation and the Core/SID/DIN/DOUT/LCD/BankStick module documentation and MIOS documentation _ before _ you start ask questions that may already be answered.
Everyone is most welcome to ask any questions of me about things that appear to be missing from the MB-6582 wiki, or if the MB-6582 wiki does not explain enough or is not clear enough. You can also post questions on the forum, there are enough other people building the exact same thing that someone can help you.
What started out as a one-off, pro-looking MIDIbox SID that suited my needs has evolved into 200+ wanting to be made by MIDIbox gurus and newbies alike. This was never my intention and way beyond my expectations, so while I understand people who have some parts already are eager to get the rest together and start building, keep in mind that if this was a real “kit” like the x0xb0x, you’d probably have to wait just as long, if not longer, until the “kit” was ready to sell, and then probably wait in line as well when demand exceeded supply.
Regards,
Wilba
