It looks like I am short two 100nF monolithic caps for C13_SID1 and C14_SID 1 (must have lost them). In a previous Core build, I bought a number of 100nF Kemet Conformally Coated Axial Ceramic Capacitors listed as C3, C7, and C8 on this core diagram.
http://www.avishowtech.com/mbhp/mbhp_coreR4c.html
The monolithic caps that came with the Smash MB-6582 kit look almost identical to the ones noted above - they look like a small yellow bead with some impossibly small lettering in red on it. They do not look like the ceramic caps pictured in the MB-6582 parts list. However, mine are not labeled as “monolithic”. Also the microscopic lettering is not identical between mine and the Smash ones (I can go get the specific letters under a magnifying glass if it helps).
Anyway, I was wondering if mine can be safely substituted. Please excuse my ignorance and thanks for the help.
The full specs are here in case it’s relevant.
Mouser #: 80-C412C104K5R
Mfr. #: C412C104K5R5TA
Desc.: Conformally Coated Axial Ceramic Capacitors 50volts .1uF 10% X7R 10%
Mouser data sheet:
