It’s strange that just those two LED’s don’t work.. do they flash briefly when you turn your MB-6582 on? (I think all LED’s do very briefly)
It might be that the LED’s are just broken, and need to be replaced.. If so, cut them out, then desolder each leg one at a time, instead of trying to desolder the whole LED at once.
Do you check the LED is good with external power by touching the LED leads on the top? Or touching the pads on the bottom?
Try also, supplying power to the pads at the bottom of the board (with resistor of course and no power to the MB-6582). i.e. try lighting up other LEDs by controlling the matrix at the JDx pads. This will test the tracks to the LED. If those LEDs do not light up with power, check if swapping +/- makes it work (test wrong polarity)
My guess is the LED might be in the wrong way, you’ve perhaps tested it works with external PSU but applied +/- differently to how the matrix applies +/-. Alternately, maybe the solder joints are not good, and you’re testing by touching the leads and not the pads.
I don’t think it is breaks in the tracks as that would mean more than a single LED in a row would not work (matrix tracks go straight through each LED pin, it’s practically impossible to have a break that conducts around the LED pin… only a bad solder joint could explain that kind of problem.
