I’m in my final stages of construction of the MB-6582, onto the CS. Sourcing the mechanical parts in question appears to be a daunting task and extremely expensive (100 spacers for 35 pounds on ebay!!).
Can somebody share any advice on sourcing this stuff in the UK,London area?
Thanks!
Hi.
I tend to use Farnell http://uk.farnell.com/ for lots of this stuff. M3x10mm threaded spacers are about 10p each:
http://uk.farnell.com/ettinger/05-03-103/spacer-m3x10-ni/dp/1466761
I had the same experience with this sort of hardware on Ebay…
Cheers
Phil
Hi.
Cheers
Phil
Thanks, for the fast reply. This really helped, I have found/ordered almost all of the parts. The only one left is the M3 countersunk head bolt. English is not my first language so I’m a bit challenged in identifying the right components. Could you please confirm if this the right bolt? Other than that I’m done with CS part’s sourcing.
http://www1.conrad-uk.com Part no.: 521676 - 89
Thanks!
Vlad
Hi Vlan.
That part looks like a spacer to me (not a bolt/screw!)
I can’t find any 25mm countersunk bolts/screws on the Conrad site.
From Farnell, I have found this: http://uk.farnell.com/tr-fasteners/m325-ksstmcz100/screw-slt-csk-steel-bzp-m3x25/dp/1419379 which is what you are looking for.
Thanks
Phil
