MB 6582 Final troubleshooting; encoders and presets
So I finally got around to finishing my MB6582. Just some final troubleshooting left (I hope):
All the encoders have some random behavior to them. They will be working fine and then suddenly the value will jump a couple of steps in a random direction, even when I’m just making a small adjustment. As I said this goes for all of them, including the one where I didn’t remove the detent.
Uploaded the standard patches but some of them are acting weird. Some are fine, some wont make any sound and some are very quiet so that I have to crank the volume to hear them. I only have one 8580 installed and I did change the setting to mono in the ensemble menu.
Suggestions are highly appreciated :slight_smile:
I believe the standard patches are set up for 6581 SIDs. There are a few settings changes you’ll want to make in the ensemble menu before they’ll work well for 8580/6582s. (Also, I think some of the patches just have the filter closed by default.)
As for the encoders… What encoders are you using? IIRC, some folks have had trouble with the “acceleration” code for the encoders. Try searching the forum for more info. Since you’re having problems with all of them, it points to either a problem with the part you’ve installed or the software.
I’m using these Bourns encoders:
https://no.mouser.com/ProductDetail/652-PEC16-4220FN0024
Chose them since they are highly recommended in the MB6582 control surface BOM:
http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582_control_surface_parts_list
But now I’m reading posts indicating that a lot of people have had trouble with the Bourns encoders. Maybe they shouldn’t be listed as highly recommended in the BOM …
Been searching and reading a lot about this but there doesn’t seem to be a solution other than de-soldering and buying other encoders. :(
Set my filters to the recommendations for 8580 found here (range 0-600 Log: on):
http://ucapps.de/midibox_sid_manual_e.html
This didn’t make any difference though; most of the patches are still really quiet. Notably whenever i tweak filter setting the range is still the full 0-FFF, and not the 0-600 that I set. Are there any other changes to be made when using 8580s?
I used those same encoders and my MB-6582 is working fine, so I wouldn’t jump to desoldering just yet.
The range shown in the filter menu will always be 0-FFF, this way you always have the same number of steps in the filter adjustment even if the internal parameter is set to a reduced range.
Instead of relying on the default patches to determine whether things are working correctly, I suggest setting up some patches from scratch.
Are you sure your SID is at full health?
I’ve got a 6581 with close symptomes but this shouldn’t explain the encoders behavior…
Ah. So even if the menu goes from 0-FFF, FFF would represent 600 if I have set 600 as max? Because my filters only seem to react roughly in the 0-600 range (nothing changes between 600-FFF) even if max is set to 600. Does that indicate a defective filter then?
Not completely confident about the health of my SID (ebay).
Did you use the “standard” setup_mb6582.hex when you got your Bourns encoders working? Should I look into any settings or other firmware?
Pretty sure, yes.
Not sure tbh, never used a busted SID. There’s always a good chance it’s an issue with how you have it patched—always tough to tell when you power up a DIY project for the first time, whether it’s busted or whether you have to learn how to use it. OTOH, eBay SIDs are notoriously sketchy, so who knows?
Pretty sure I did. But maybe there’s an acceleration/debounce setting in the firmware that I’m not remembering.
Have you tried it without the SID?
Done some more testing tonight. All the patches that work normally either doesn’t use the filters or use high pass filters only. All the other patches are really really quiet. If I crank the volume I can still hear them (barely among the noise from the SID). If I sweep the filters there are no smooth filter sweep. Instead sounds cut in and out suddenly. If I change filter mode to high pass the patch starts working normally and at normal volume (way louder!). The filter sweep is also much more smooth when in high pass mode.
I assume that this points toward broken filters in the SID. Anything else I should consider/try? Haven’t tried switching filtering caps. But I think they should be fine.
there are some conflicting values for the caps around I found - although the ones for MIDIbox SID usually seem to be the correct 22nf, I found places that said 220nf and was a bit confused (probably not but worth mentioning I thought.. I tried building a different SID project with the wrong caps and the behaviour was not far off this)
That behaviour does also sound really similar to what was happening with mine when I didn’t have the log flag to “On”, and I was convinced it was broken… but you’ve tried that.
Can you try the SID in other socket of the first core? (can’t actually remember if that works, but if it does it at least eliminates an issue with something around the socket)
It’s starting to sound (to me) like maybe the filter on your SID is blown. But as I understand it, blown filters are not nearly as common on 8580s as they are on 6581s, so I think it’s worth following duckchild’s advice and really double and triple checking that all your patch settings are correct and that your filter caps are the correct value and installed properly.
Triple checked the caps. Even dug out another pair of different caps with same value and tried with those instead. Same result.
Sounds like a good idea to try in another socket. I’ll just have to get a proper IC removal tool first. I really don’t want to break the SID (any more that it might already bee). I actually ordered 4 8580s on meeblip. So hopefully, in not too long, I’ll have some more to compare to.
Did you sort out the problem with your encoders? My MB6582 behaves just like you describe. It usually works pretty good once the encoders have been used for a while, but when the box has been on shelf for some time they are mad.
I would believe the encoders are jumpy and that the software should be tweaked to wait longer to confirm a step. Maybe there is a firmware out there with some tweaked settings?
Sounds like a possible encoder debouncing issue?
This article may shed some light:
http://www.buxtronix.net/2011/10/rotary-encoders-done-properly.html?m=1
Quote
The vast majority of encoders suffer from one or more of the following flaws:
•    Debounce handling. Mechanical switches are imperfect, and bounce on and off during transitions, over a few milliseconds, which is enough to be sensed as discrete changes by the MCU. Many implementations simply detect a change from 00 to 01 and signal it. But with switch bounce, it could be detected as many events. Thus, implementations often include debounce routines. but these add additional code, and also at high rotational rates, they filter out the events and break.
•    Direction changes. Some implementations use algorithms that expect direction changes to occur at the ‘00’ bit position. If a change occurs mid-step, they get confused and return too many events, or a spurious one in the wrong direction.
•    Complexity. Many implementations are plagued by complicated conditionals and loops. They have unwieldly long if-then statements that are impossible to debug, yet can still suffer from the above problems. Complex code also leads to consumption of valuable code space.
•    Weak algorithms. Far too many implementations simply look for a single transition from one state to another, rather than following and checking for valid states. This leads to odd quirks and bugs.
The recommendation is to implement better debounce handling in the code…
I haven’t looked at the section of the MB-6582 firmware that handles the decoders, but perhaps someone more familiar could comment?
