Does anyone know where I can buy a DIN 7 socket in the US that matches the pinout on the MB-6582 PCB? I purchased some from Digi-Key, but the footprint was wrong. All the other DIN 7 sockets I’ve found on other sites match the pinout from Digi-Key, not the one on the MB-6582 board.
Can you post a link to the part from Digi-Key? I’d like to know how the footprint is different.
For your trouble, I will post you one that fits for free, send me your address in a PM.
I had the same problem. This seemes to be a more or less standard footprint: D7 (CL1909) @ http://www.farnell.com/datasheets/59156.pdf
I guess yours have the same footprint eventhough they are not from the same manufacturer, skyline7.
I believe the 8-pin DIN socket in that datasheet has a footprint that matches the MB-6582 base PCB, but with an extra pin (pin 8) which you could trim off.
I will have to check the dimensions more carefully. I know SmashTV was considering using 8-pin DIN sockets in the kits for various reasons, the socket itself would be compatible with the 7-pin DIN plug of a C64 PSU.
Here’s the part I ordered that didn’t fit:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=CP-2370-ND
Well, that’s annoying… not even the 8-pin from this manufacturer will fit.
I used the same footprint as the DIN socket in the C64, and I bought a bag of 100 at the time which had the same footprint.
I expected it to be a standard, much like 5-pin DIN sockets (aka. MIDI sockets).
One free socket to skyline7! ![]()
Just PM me your details.
Not even the 5-pin socket seams to have a standard footprint. I have seen at least two…
Hi, I found a DIN-7 at Elfa (42-239-13) that fits the pcb. See http://www1.elfa.se/elfa~eu_en/go.jsp?s=eu-en&a=0/48C87B88DDE7453BE10000000A0A036A/48C91B2A04D6453BE10000000A0A036A/48C91DBE04D6453BE10000000A0A036A/48CB75A981B7453BE10000000A0A036A
/offe
