making this midi-hardware?
Hey everyone… I really hope someone can help me with this:
I want to build a midi controller for my Digitech whammy pedal.
The pedal has an midi-input, and can be controlled like this:
Midi progam change 1-34 changes the sounds
Midi CC11 change the treadle position (that bends the pitch)
Midi CC0 turn the effect on and off…
Now… I am really handy and have knowledge about wiring and programming. And I want to make this hardware that should be build into my guitar. All it has to contain is this:
A switch has to toggle the effect on and of  (CC0)
A potmeter that controls CC11
2 buttons has to be able to change the banks (program change 1 - 36)…
I’m really a newbie, but hey… you have to start somewhere. If someopne would guide me very down-to-earth and say what I should begin with, I would be glad.
I have attached the manual for my guitareffect, if my explanation was too bad..
  - Rune
[Whammy.pdf](< base_url >/applications/core/interface/file/attachment.php?id=77)
[Whammy.pdf](< base_url >/applications/core/interface/file/attachment.php?id=2894)
Check out the MB64 or MB64e and meta events :slight_smile:
What if your guitar gets damaged? It won’t be of any use anymore… why not building it in a floorcontroller?
Electric guitars have cavities in the back, it would be just a matter of using a screwdriver and socket wrench to move the device from one guitar to another.
Yeah, I really want it to be in the guitar. That is the idea :slight_smile: Or else I could use the pedal itself :slight_smile:
Oh yeh don’t forget about power. There are other threads that have covered this topic, search around for ‘guitar’ and ‘midi cable power’ and stuff…
Could someone please guide me a little bit. Maybe just explain the basic parts I need to do this?
check out the wiki and ucapps.de and look at the MB64 or MB64e applications, that’s the best way to explain it.
Ok, have spent a lot of time reading around, and this is what I came to that I have to use:
1 Core Module (Pre-burned full kit)
1 LCD Screen 2x20 Characters - For debugging purpose
1 AIN Module (all parts mounted) - For my 1 pot
1 DIN Module (all parts mounted) - For my 1 on/off button (have skipped på bank-change idea)
.. And off course wires, MIDI-jacks, buttons and potentiometers…
As I see it I can connect these things, upload MIOS, upload MIDIBOX64 software and then get started.
The only thing I can’t figure out is the softwarepart - how to program the pot and buttons to send the desired signal to my guitarpedal.
Does this look allright?
heya rune…
Good news, if you only want to use one pot and one button, it should be possible to do some minor software customisations and you will not need an AIN* module or DIN* module - so you may only need the core :slight_smile: Forgive me but I’m not sure how to go about it exactly, but there are instructions and examples to be found on the ucapps/forum/wiki sites.
To customize the signals that you use, you can use the ‘meta events’ feature. Seeing as your application is quite simple, there is an alternative to the MB64 with meta events, if you have some C programming knowledge - you could write your own specialised application. You can find information on how to do this at the above sites too, but I would only recommend this option if you have some programming experience.
Ok… thanks for replying  :slight_smile:
I am a pretty experienced programmer in PHP and Flash actionscript, so I will look into it.
Thanx again!
Check this online book out for getting to know the language, it was the one that made C ‘click’ for me… http://publications.gbdirect.co.uk/c_book/
There are examples at http://www.ucapps.de/mios_c.html , between those two and your experience, you’ll be set.
…That reminds me, I have to update the documentation on the IDE (Code::Blocks)… Should be done within a few days, but you won’t need a graphical debugger just yet, so you could start in notepad or something :slight_smile:
I have thought about it, and I think that I’m going to make 4 pots and 4 buttons, therefore sticking with the list above. If I do that, I can use it to control a bunch of other things :slight_smile:
Is it then not easier to use the MIDIBOX64 software? and then using META-events?
I think that I’m going to skip the programming for now :slight_smile:
Sounds like a good plan :slight_smile:
wouldn’t it be easier to have the core separate from the guitar, and run the leads to the pots and buttons from that to the guitar using a 9 pin RS-232 cable? i don’t know how roomy your guitar is, but surely it would be better that way. (it’d also prevent you from having to replace the core every time you smash your guitar up on stage - if you do that sort of thing… ;D)
hmm… how big is the core? I can’t find any dimensions on it… :frowning:
But I surely won’t smash my guitar having spent months building it :slight_smile:
it’s not big: 64mmx82mm, my suggestion was just an alternative so that you wouldn’t have to trail power and midi up to the guitar.
You’ll at least have to have the AIN module in the guitar to avoid noise between the pots and the ADC.
^^^ that’s true, which is why an encoder would be better.
Word has it that it’s pretty much the same for DINs… Just too much noise on a line like that…
I don’t know if there’s any advantage of a DB9 over a DIN plug though?
