Hello all,
After a year looking around on this forum and making several ideas, i think i have come to my final idea. I want to make faderpacks for a Tascam DM-4800. They will be faderpacks of 8 channels. I’m thinking about using the default Midibox LC application as it will be 90% what i want. So hardware will be as follows per faderpack:
- 1x Core
- 1x MF_NG
- 4x DOUTX4
- 4X DINX4
And the default LC application offer me the following per channel:
- 1x Alps Motorfader
- 1x Mute Button
- 1x Solo Button
- 1x Select Button
- 1x Rec Button
- 1x Mute Led
- 1x Solo Led
- 1x Select Led
- 1x Rec Led
- 12x VU Leds
- 12x Rotary encoder ring leds
- 1x rotary encoder
So this is exactly the default Midibox default LC application. Thought i would like a few addons/modifications:
Can I use the MF_NG module the same way as the legacy MF Module?
for each channel i would like a 0.96" SSD1306 OLED screen, how would i do this? And i would actually use 2, but they would show exactly the same, can i just put them parallel?
I’m not planning on using the other stuff from the default LC application, can I just leave this out? e.g. leave the coding the same, only not connecting the leds and switches, etc.
- How would the midibox NG fit into this picture? (Maybe a noob question, but I’m a bit confused about this).
Looking forward to your ideas folks!
Regards,
Henk
