That is really funny..I am having the same problem at the moment, my MIDIO128 doesn’t work either and the file size with me is also about 1.5kB. It should be about 8k? How do you know that?
i have just successfully used midi-ox to upload the syx file without any problems.
to clarify what i did…
1. installed mios with mios studio
2. installed midio128 with mios studio using the midio128_v2_1c package
3. configured midio128.ini from the mk_midio128_syx package
4. run the batch from a cmd prompt as per the mk_midi128_syx readme (needs perl)
5. configured midi-ox as per the readme from mk_midi128_syx
6. uploaded the midi128.syx file to midibox
7. tested the configuration - and it worked without a problem.
i have tried using sysexbox_18f_v1_1c, but without success, but i think that was from a totally unrelated problem with power supply (which i have rectified). i have not retried using sysexbox, so i don’t know if it works as expected.
