Hi all,
I’m just dipping my toe in the water at the moment as far as midibox goes!
I’m planning on building a controller for my Alpha Juno which uses a whole lotta sysex.
I’ve downloaded the Midi Box editor (vmidibox) so i can start to test out some ideas before i start to build anything. it seems to happily send out midi info etc, which is a good start!
I’ve also downloaded the midibox64 files, and started to try and get to grips with meta events, and using mk_syx to create sysex files to load in the virtual midibox.
What I’m wondering is - when using mk_syx, where does it look for the mb64_meta file, ie where do i put it? I tried simply putting the file in the same folder as the midibox**.ini file that i’m using to generate the sysex, but this doesn’t appear to be working.
Apologies if I’m being exceptionally dense here, I’ve had a good go at searching the forums but not managed to find an answer yet!
Yours,
Gav
