Hello everybody,
First of all, I’m not a beginner programmer…more
I was trying to setup and install the toolchain following the tutorial I found here Mios32Mac but unfortunately at the end of the setup, I tryed to run the Tutorial (midi_forw) with a nice, bad surprise.
I attached a txt file of my terminal error msg…hope it can help [TermErrMsg.txt](< base_url >/applications/core/interface/file/attachment.php?id=9331)
I was searching a bit on the forum but I found topics more for Windows user..I have a Mac Os X 10.6 system.
Really hope in your help!
thanks in advance
greetings
gianluki
Hi.
Does the file: $MIOS32_PATH/include/makefile/common.mk exist?
If not, you have not successfully checked-out the MIOS32 source. Try the checkout again:
svn co svn://svnmios.midibox.org/mios32
Thanks
Phil
Hi Phil, and thanks for your support!
Yes at that time I did it, but to be sure, I deleted everything and I’m repeating the installation now again…in real time :)…I will just jump the part concerning the “svn” command which I already did following the tutorial at “rubyrobot.org”.
Step by step:
- I create the “svn” directory and went in with cd svn
- I moved Inside this directory and checkout the repository
- After his process, I got the msg “Checked out revision 1351”
- Now, my mios32 folder is inside the svn folder I created before
- Downloaded the toolchain,extracted and moved it under svn/mios32/trunk
- Tested with the example “export MIOS32_PATH=~/svn/mios32/trunk” and the echo..
- Set up the path variables…in my case I would like to use the LPC17 so I exported this “export PATH=$PATH:/usr/local/mios32_toolchain/bin”…and then the others from the lpc17 group at the bottom of the tutorial page.
- Tryed to run the tutorial…
- Got another..new error…see my “terminal” text file I attached…
[TermErrMsg2.txt](< base_url >/applications/core/interface/file/attachment.php?id=9336)
- The different things I did during these steps was to delete the empty “include” and “bin” folders before I moved the mios32 toolchain under svn/mios32/trunk…I think my mac overwrite the folders…result…they where then empty…no common.mk file inside…now is there
At this point looks like I should not have anymore the problem with the make file…but something with the “arm-none-eabi-gcc” folder.
Any tips please?
thanks a lot and sorry for my English.
gianluki
You should check if there is a binary called: arm-none-eabi-gcc in the directory /usr/local/mios32_toolchain/bin
If it is there, then there is a problem with your path. Check your path with the command: echo $PATH (in terminal)
Check and see if /usr/local/mios32_toolchain/bin is in it.
If is not there then you should unpack ftp://ftp.lansystems.co.uk/pub/midibox/mios32_toolchain_intelmac_20101024.zip again.
Hello and really thanks all for your support!
For Shuriken: I did it,I checked my path and seems ok …I even see the file arm-none-eabi-gcc but nothing work,always the same error message
I did all the process again just right now, Toolchain freshly dowloaded,etc..but nothing changed, still missing that file, even if its there.[TermErrMsg3.txt](< base_url >/applications/core/interface/file/attachment.php?id=9350)
Any suggestion? from my side… I just feel soo stupid but I really don’t know what is wrong.
Thanks again to all of you.
gianluki
Very strange. Does the command “arm-none-eabi-gcc” work in a terminal with that path setting?
I don’t know how to check it.. :ermm:
I run the file serching it through the finder and then double clicked on it…here a copy of my terminal msg…which automatically opened after double-clicking on the file [TermMsg-anegcc.txt](< base_url >/applications/core/interface/file/attachment.php?id=9352)
I also found a similiar one called “arm-none-eabi-gcc-4.5.1”..run it by double clicking…and got the same msg like for the “normal” one.
I was also tryng to repeat the process on a Windows Xp machine…in that case I get blocked in the step:
- "Under User variables, select the variable ‘PATH’ and click ‘Edit’
My user variables just have 2 strings, one is called TMP…the other I don’t remember…but sure nothing which start with PATH..
Again, really thanks a lot in advance to all of you which are supporting me!
I really hope that after this problem…I will start to use the forum to support too…of course with other skills I have..ehehehe
gianluki
