Looks like you basically dangle a magnet above them and they give you the absolute angle over a serial interface. I got some samples, I’ll let you know how they turn out.
the mainly question is where to get the magnet for that…
and whats the priceing for that…5$ are a bit to much for peace of silicium :o , if this would be cheaper then a mechanical encoder - i would start to thinking of cnc designes for axis, shafts and so on… but with 5$ i dont start to think about that…
:D you may need a tiny tiny tiny magnet… because, you have to put many of this tiny tiny magnets on a tiny tiny disc…and because you need a better resolution then, one step by one turn
or you could take a magnet disc, and the take magnetic shielding stuff (What ever this is) that is easy to drill with a cnc, and then drill isolation areas in the stuff… it then may look like a disc from a optical encoder… then you put the shield-disc on the magnet-disc, and so on… oh man too komplex…
It needs one radial polarized magnet in the center of the encoder spindle. The encoder works “analog”, with hall elements and proximity ratio.
