Mackie d8b motorfaders
I am able to get some motorfaders from a mackie d8b console at a good price.  I would like to know if anyone knows if these will work with MBLC??
… try to get the datasheets of the faders from Mackie
Greets, Roger
Jeroddumas,
if you get the datasheet, I’d be interested in a copy.  :wink: But I don’t think Mackie will give them away. I had bad experience with Mackie getting detailed HW informations. They more or less ignore such enquiries. They want you to buy their equipment, not to clone it.  ;D
Cheers & Good Luck,
Skunk
I have recieved the service manual for the d8b from Mackie.  I have nowhere to host it.  If someone wants to help out let me know.
Hmmm, interesting… you rreally got the service manual? In the service manual you normally find a list with all the parts used in the d8b, often called BOM = bill of materials. In the schematics you need to identify the faders with their corresponding part IDs. Take the IDs and cross check in the BOM for the corresponding material name. Normally you should find there a part number and may be also the supplier. If you got this, then let’s proceed.
Cheers,
Skunk
Here’s the PDF’s…
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
Thanks to jeroddumas  :wink:
I’m thinking these motorfaders will work.  It looks like they run off 5v.  I think it will just be a matter of finding the pinout.  Any other thoughts??
Hi Jeroddumas,
I’ll try to find some time over the weekend, check it and drop you a note.
Cheers,
Skunk
Hi again,
I just checked the schematics. Have a look on Sheet 125-3. The fader is powered by a discrete bipolar transistor H-Bridge running on 12V. I assume the faders used are cheap licence build according to P&G, but manufactured in Far East. The motors used could be Panasonic, so the power for the motor is mostly in the range of +8V…+12V. Unfortunately the BOM doesn’t give any indication about the manufacturer since it just says: motorized 100m faders.
Cheers,
Skunk
So they should work fine???  I am going to order them Monday.
Here’s the PDF’s…
…clip…
Could we get these back, I would love to take a look, too.
