LTC module in 2 cores configuration
hey experts,
I’m in a 2 cores configuration.
I want to use a LTC module only for midi  in out monitoring.
but with the midi link, core1 get MIDI IN from the external world, and core2 send MIDI OUT to the external world…
so, how should I wire the LTC in that case ??
indeed, I’d like to monitor the midi that comes from the world inside the box (MIDI IN LED on LTC) and the midi messages that goes to the world (MIDI OUT led on LTC)
should I use M+ from J13 (IN) of the core 1  and M+ from J12 (OUT) of the core 2 to feed LTC ?
any help would be very appreciated :slight_smile:
fuse link=topic=13911.msg119606#msg119606 date=1250372752]
Yes, this will work! :slight_smile:
The LED stages of the LTC module are nothing else than two monoflops - you can connect any digital source to LTC::J1:MI and LTC::J1:MO
I’d like to add this to docs, could I?
it could be useful for geek like me :slight_smile:
thanks a lot Thorsten.
I keep you informed about my project as I’m in a full OpenSource mind and I’d like to spread knowledge as far as possible :slight_smile:
