LTC Module hookup
I want to use an LTC module with my MIDIBox SID (quad). If I use it as an extra MIDI port (MAX232 out), do I connect it to the master CORE module only, or to all CORE modules?
Hi Thomas,
it has to be connected to the CORE module, only.
See also this special diagram for MIDIbox SID:
(more diagrams can be found under http://www.ucapps.de/mbhp_ltc.html)
I think I am clear now. The LTC should be connected in parallel tp J11 of all CORE modules as the diagram shows.
