I want to use the com port interface and the standard midi interface. I´ve read that I can´t do it at the same time. so my question is: can I add a switch to change between this interfaces taking pic pins 25,26 to the switch? Is it a problem if I change the interface while the controller is turned on?
this should work - also during the PIC is running - but you have to add an additional pull-up resistor between the Rx pin and +5V in order to avoid random MIDI events during the switch phase.
P.S.: the switch is only required for the Rx pin to change between the optocoupler and RS232 signal
Scuzzle: of course, you’ve to take care that the correct baudrate is selected (it’s a special menu entry in MB64/MB64E/MBMF). But there isn’t a problem so long as the cables are not connected to the port which runs with the wrong baudrate.
Pull-Up: two solutions:
cut the track between the Rx pin and R6. Use a resistor value which is much greater than R6, let’s say 100k. Then it won’t affect the optocoupler output signal
or:
Don’t cut the track directly at the Rx pin, but between IC2/Pin 6 and R6, so that you don’t need an additional pull-up resistor.
Since I would prefer method 2, here more details:
Rx Pin: connected with R6 and the switch output
IC2, Pin 6: connected with one switch input
J11:MI: connected with the other switch input
Once you get this running, please draw a schematic, add some comments and publish it at the MIDIbox Portal, since it could also be interesting for other people.
You could add some lines of code into the application which switches between the baudrates. I can tell you more details once I know which application you are planning to build exactly
MIDIbox 64 with PIC16F877. I´ve also planned to put 16 leds (one for each button) for mute and solo. Is this possible, does it work properly using it with Cubase, reason, sonar, etc…
