LPC1769 - load MIOS32 Bootloader
After some futzing around I think I successfully loaded the MIOS32
bootloader. I don’t have my parts from SmashTV yet so I can’t test
it (or can I?) so could someone confirm, the LED blinks three times
and then goes off and then comes on and stays on. Is this what I
should be seeing? Thanks.
Yes, your core module is up&running!
Thanks Tk! Now I’m working to get I’ve got the board split into two pieces using a ‘box-cutter’ and multiple passes.
Hi all,
i can’t load mios32 bootloader, when i click on the icon “program flash”, there is nothing inside the box.
When i try to open project.bin, computer says it isn’t a valid Win32 application.
Any idea?
Some news, i have the file project.bin into the project window, and when i click on the icon program flash, it says: “project project has no MCU information”
No problem with the file project.hex, i can be opened, but i didn’t found yet how to send it into the board.
yeah!!! it works, the LED blinks three times
and then goes off and then comes on and stays on , i think it is ok.
In File, i selected New, other, selected LPCXpresso C project, select wizzard C project, named it “test”, select target selection LPC1769, and select None in CMSIS options, and it create a project on project window at the left, and after that i was be able to click on the icon program flash, i browse the project.bin and click OK, and it has been done.
