I have made a PCB that breaks out all the I/O for 5v buffered gate triggers and additional midi ports that are found on LPC17 and CORE32 for MBSeqv4.
The goal is to break out all the connections using 2x5pin IDC Headers that will connect 1:1 with the corresponding headers on the core module. The attached files are for LPC17 (which I am currently using) and they can be easily modified for core32 (swap midi I/O pins, etc.)
I have integrated 5v level shifters for the 8 gates and clock start/stop etc. I have also integrated the necessary hardware for Midi I/O ports 3,and 4 (optos, resistors, etc.)
I would like to make these additional midi ports operate at 5v (instead of 3.3v) to ensure compatibility with older midi devices. I’m not sure what changes are necessary to do this. As you can see there are quite a few pins free on the 74hct541 if those are required, I was wondering if I supply the “m+” pins (on the midi out ports) with 5v instead of 3.3v will this achieve the same result? If so, should the 220ohm resistor be changed to a different value?
Please have a look at the eagle and quick view files I have attached. Your input is greatly appreciated!
I have revised the PCB according to an updated schematic TK provided. This latest version is a bit simplified, I have eliminated MIDI I/O 4 (reserving this for the BLM connector down the road) and I have buffered the Midi 3 output to 5v with one of the free pins on the level shifting IC.
I’m very interested in Your PCB/Project (building a SEQ V4 right now)!
Lemonhorse
That’s great! I just ordered the components for it yesterday. I’m going to etch the pcb and assemble it over the weekend, I’ll let you know how it works out on monday. In the meantime, I’m open to suggestions for how I could improve this board. Do you think it is wise to add two more ports for midi i/o 4 ? or should I just add a single port for the blm connector? I could also add midi thru ports, but they may be redundant if the MBseq has a “soft” midi thru function (I just got my seq up and running last week, so I still have a lot to learn about this amazing software.
the board looks great - i´d recommend to add MIDI OUT4 and MIDI IN4 for more general purpose usage - a BLM can be connected e.g. with an external cable harness that connects to both ports…
Also, methinks MIDI Thru is not necessary, as you can do all sorts of routing from within the SEQ router…
Below you will find a .rar archive which contains:
.brd file (you may open and modify with eagle)
full color quick view to assist in assembly
negative monochrome render of bottom traces, pads, and vias (for negative photo resist process)
positive monochrome render of bottom traces, pads, and vias (for positive photo resist process)
#4 has been optimized in photoshop to use less etchant (this is the one I will be using)
I will be receiving the components for this board today. I’ll let you know how it all works out after this weekend. In the meantime, if someone spots an error, or has some suggestions to make, please let me know!
okay i will wait…printed the PCB right now but good that i looked once again here on your thread…
i have a question to you…is there any possibility to add the BLM-connector directly to the PCB? I red Hawkeye told something about a Y-cabel-adapter to make the BLM-connector from both additional Midi-Ports of your PCB. is there only the possibility eighter the MIDI-Ports or the BLM-connector is there a possibility to have both (two additional MIDI-Sets (MIDI IN/OUT3 and MIDI IN/OUT4) plus BLM-connector?
i hope you understand my question.
Regards
MaG2k
The BLM connector occupies one set of midi in/out, so this is not possible. If you need more i/o check out the i2c midi module for up to four more midi outputs
