Hello Folks!
I am designing a MBLC and was considering integrating it into an exsisting mixer (Yamaha MG16/4) but the only problem I can see with it at the moment is that fact that MBLC uses linear faders, whilst my mixer uses logaritmic faders. Is there any way in which I can use logaritmic faders with the MBLC and also be able to control them both at the same time using the same fader?
Cheers
Antony
the mblc isn’t a mixer. just a controller. it’s down to whatever DAW software/hardware you use it with.
hope this helps.
Hello,
I intend to integrate functions from the MBLC into a current mixer, on seperate systems but with everything in the same box if that makes sense, I probably didn’t make that clear! Does anybody no where I can by dual rail linear faders from, with rails for the control voltage (0V-+5V) and also a standard audio fader?
Thanks
Antony
sorry, i still don’t understand. you’re going to integrate an mblc with a mixer? how??? is it a digital mixer? i just don’t get it. sorry for being dense!
