Loading snapshot without triggering
Hello,
Is it possible to load snapshot without triggering the assigned MIDI command and witjoit executing of fwd_id?
I need to do yhe following:
  1. Load the snapshot (the defined values by no_dump) and do nothing - at the moment it is loading values than dumping, I need loading without dumping
  2. Send 2 Progra change commands (based on the loaded values) one fkr ch1 and one for ch4 - solved in NGR
  3. Wait 800ms - solved  in NGR
  4. DUMP SNAPSHOT - it is working, solved in ngr
  5. Activate and deactivate senders based on the loadwd LED values - it is working, solved in NGR
Is there any solution, or can I put it to wishlist for Midibox NG as Load_nodump_snapshot command?
Frank
Really nobody has experience with that? Who can I contact directly, do you think?
Frank
The other solution of my problem could be the loading of only few defined parameters not all the snapshot. In that case I could load parameters which are sgoring the program change numbers which I need to send the sound module than load the whole snapshot and send cc numbers automatically at loading.
