Linking two LPC17 cores
Hello dear community,
if I might ask about the following:
http://discourse.midibox.org/t/topic/17512
The two cores need to talk back to one another.  The sequencer will have the soundboard as its default output, and the midio needs to send back switch and expression pedal signals to the seq v4 core.
I cross-wired J5B.A6 and J5B.A7 for midi in/out 3, but this creates midi feedback: the cores lock up in sending each other the same messages over and over again.  The routers are not yet set up at all, so i guess it is not in there.  I read up on mbnet, but i don’t understand it and it will require extra programming in the seq v4  code, which maxed out the capacities of the core already. I’d really appreciate your debugging tips and suggestions.
And by the way, if anyone could recommend a good audio signal quality DPDT 5V relay that latches on pulses, i’d really appreciate that as well.   The midio128 will become a guitar fx looper/ switcher then with an extra DOUT.
Thanks for your ideas!
you did it right - the most simple way to link two cores is a common MIDI IO crosslink, and MIDI3 was a good choice.
But I’m surprised that you get a feedback.
Could you please enter the “router” command in both applications, and copy&paste the terminal output into this posting?
Thank you TK, you’re very supportive
this is the router output from the SEQ V4 application
[13234.128] MIDI Router Nodes (change with 'set router <node> <in-port> <channel> <out-port> <channel>)
[13234.129] Example: set router 1 IN1 all USB1 all
[13234.129]    1  SRC:Def. off  DST:OUT1 off
[13234.129]    2  SRC:Def. off  DST:OUT1 off
[13234.129]    3  SRC:Def. off  DST:OUT1 off
[13234.129]    4  SRC:Def. off  DST:OUT1 off
[13234.129]    5  SRC:Def. off  DST:OUT1 off
[13234.129]    6  SRC:Def. off  DST:OUT1 off
[13234.129]    7  SRC:Def. off  DST:OUT1 off
[13234.129]    8  SRC:Def. off  DST:OUT1 off
[13234.130]    9  SRC:Def. off  DST:OUT1 off
[13234.130]   10  SRC:Def. off  DST:OUT1 off
[13234.130]   11  SRC:Def. off  DST:OUT1 off
[13234.130]   12  SRC:Def. off  DST:OUT1 off
[13234.130]   13  SRC:Def. off  DST:OUT1 off
[13234.130]   14  SRC:Def. off  DST:OUT1 off
[13234.131]   15  SRC:Def. off  DST:OUT1 off
[13234.131]   16  SRC:Def. off  DST:OUT1 off
[13234.131]
[13234.131] MIDI Clock (change with 'set mclk_in <in-port> <on|off>' resp. 'set mclk_out <out-port> <on|off>')
[13234.131]   USB1  IN:on   OUT:on
[13234.131]   USB2  IN:off  OUT:on
[13234.131]   USB3  IN:off  OUT:on
[13234.131]   USB4  IN:off  OUT:on
[13234.131]   MID1  IN:on   OUT:on
[13234.131]   MID2  IN:on   OUT:on
[13234.131]   MID3  IN:on   OUT:on
[13234.132]   MID4  IN:on   OUT:on
[13234.132]   IIC1  IN:---  OUT:---
[13234.132]   IIC2  IN:---  OUT:---
[13234.132]   IIC3  IN:---  OUT:---
[13234.132]   IIC4  IN:---  OUT:---
[13234.132]   OSC1  IN:on   OUT:on
[13234.132]   OSC2  IN:off  OUT:on
[13234.132]   OSC3  IN:off  OUT:on
[13234.133]   OSC4  IN:off  OUT:on
and here it is from the midio128.
[13234.131]
The SEQ v4 keeps sending midi FC bytes when paused or stopped and FA bytes when playing.  The midio128 is in a loop always mentioning song position and won’t give the router info when the seq is connected.  I’m still with midio 3.13, need to download the repository and recompile my MB50XG project. the seq is v4.078. Maybe the problem is in my db50xg code..
Hope you see something!
It’s the BPM generator which generates the FC events, the router commands shows that IN and OUT are enabled at both sides.
So, try:
set mclk_in IN3 off
set mclk_out OUT3 off
at both cores to avoid the feedback.
Oh thank you!  I will test that. I took out one wire, so I’ll have to solder it back on again.
But basicly, both cores are drowning one another in clock signals, right?  I uploaded the prebuilt midio128 v3.16. it has clock filtering in the menu right; and the seq v4.078 does not.
yes
MBSEQ has it in the BPM page
TK you’re like a heat seeking missile. Works like a charm! Thanks a million!
